People with the Wilwood 4pot brake kit
Turbo-Brown
Boost Junkie
Post Tue Oct 11, 2005 8:08 am
Just a quickie, have people been using a bigger master cylinder or is the standard one alright?
Cheers!
Dan318-is
Post Tue Oct 11, 2005 8:20 am
i aint uprated my brakes with willpot
but if u want better braking performance u need a smaller master cylinder and a bigger slave cylinder mate
Turbo-Brown
Boost Junkie
Post Tue Oct 11, 2005 8:29 am
And bigger discs and a larger swept area :)
I'm guessing that the volume of the calipers is bigger than the old single piston's, but I don't really want the pedal dropping to the floor every time I go to slow down.
Andy335Touring
Post Tue Oct 11, 2005 7:58 pm
jmc330i
Post Tue Oct 11, 2005 8:05 pm
You got the 280mm kit that was designed for the E30 from Rally Design didnt you??
Have a word with them, I thought all their car specific kits were designed to run with the standard master cylinders.
James
'91 325i Sport
'93 318i touring 16v
Post Tue Oct 11, 2005 10:00 pm
u need 17's though as the calipers are massive and stickout alot both sides of the hub
jmc330i
Post Wed Oct 12, 2005 5:22 pm
Simon13 wrote:u need 17's though
Really? I thought the Rally Design 280mm kit was designed to fit behind 15" wheels - thats what it says in my catalogue and on the web site.
James
'91 325i Sport
Sirnixalot
Post Wed Oct 12, 2005 5:44 pm
318-is wrote:i aint uprated my brakes with willpot
that makes no sense.
In the braking system the calipers are the slave cylinders. If you have a caliper with a large fluid capacity and a small master cylinder, the master cylinder will not be able to fill the calipers and extend the piston(s).
If anything you want a large master cylinder and proportionatly smaller calipers. :wink:
Turbo-Brown
Boost Junkie
Post Wed Oct 12, 2005 6:57 pm
They did just about fit in a set of 15" wheels with a 6mm spacer (my beloved 15" wheels that turned out to be bent :( )
But the 17" wheels I've got have enough clearance to the back of the spokes to need no spacers :)
A smaller M/C and larger caliper piston area will give the driver an increased mechanical advantage (more leverage) at the expense of increased pedal travel.
Sirnixalot
Post Wed Oct 12, 2005 8:59 pm
Turbo-Brown wrote: A smaller M/C and larger caliper piston area will give the driver an increased mechanical advantage (more leverage) at the expense of increased pedal travel.
That i agree with. Once your master cylinder can fully actuate the calipers in its stroke its size is perfect/adequate for the job but it might not meet the drivers personal prefference for feel.
