Rear screen
NIX
Tue Apr 05, 2011 11:28 am
Hi guys,
In need of a new rear screen/window due to the heating connectors being broken.
Any idea of how much this costs and who would be the best people to contact? I'm based in North London.
Cheers!!
Nick
**BANNED**
Tue Apr 05, 2011 11:48 am
Rear 'screens are not the sort of thing that gets damaged or broken so should be readily available s/h.
Try a 'wanted' add in the correct section.
Youth is wasted on the young.
NIX
Tue Apr 05, 2011 12:01 pm
Thanks, but going to need someone to fit it too...
**BANNED**
Tue Apr 05, 2011 12:05 pm
NIX wrote:Thanks, but going to need someone to fit it too...
That should not be a problem for most of the zone's 'frequent fraggers' or 'approved traders'!
May be a little more difficult if you cannot travel far from North London,though!
Tue Apr 05, 2011 1:11 pm
I've got an untinted one with working heating element and the connection tabs intact- you can have it for £10 but you'd need to collect it from me ( 20 miles north of Birmingham )
Tue Apr 05, 2011 1:16 pm
how do you check if it demists when removed from the car ?
i have a charged 12v battery and a multi meter winkeye
Tue Apr 05, 2011 1:17 pm
It worked last time I used it :wink:
Tue Apr 05, 2011 1:25 pm
capri_rob wrote:It worked last time I used it :wink:
mines a spare that i forgot to check before i fragged an old turd and if it works i'm using it.
the rear demist has never worked on my car since i've owned it but that could be a fault somewhere else in the car maybe ??
NIX
Tue Apr 05, 2011 1:26 pm
Thanks guys but not really looking to trek that far. Don't mind a bit of a drive if it includes fitting but not as far as the midlands.
Thanks anyway!
Tue Apr 05, 2011 1:31 pm
Does windscreen insurance cover the rear screen ? winkeye
beemerbird
Tue Apr 05, 2011 1:43 pm
Do you still have the tags in your possession? I successfully attached tags from one (unfitted) screen onto the one that was fitted to my car. Or someone may have a broken rear screen that they can prise the tags off for you . . . . . . I'll find a link to the stuff I used to do this.
beemerbird
Tue Apr 05, 2011 1:49 pm
NIX
Tue Apr 05, 2011 1:56 pm
Hi beemerbird, that MIGHT work...Basically the connectors that attach onto the rear screen look as thought they've been snapped off - maybe the rear screen was replaced in the past and these bits not fixed back properly, not sure.
Perhaps I'll try to take a pic at some point to show what I mean.
beemerbird
Tue Apr 05, 2011 2:24 pm
NIX wrote: the connectors that attach onto the rear screen look as thought they've been snapped off - maybe the rear screen was replaced in the past and these bits not fixed back properly, not sure.
That's exactly what had been done to mine, hence my use of the glue. I bought a second hand screen for a tenner, heated the intact tags with a soldering iron until they floated off. Then fitted the tags to my installed screen. Far less hassle IMHO.
NIX
Tue Apr 05, 2011 2:42 pm
Will take a closer look and see what I can do.
Cheers!! :cool:
abelai
Fri Apr 22, 2011 12:28 am
Hows it going? What you up top these days? I'm impressed to see you still have the e30.
Speak to you soon, Ryan.
If I can't fix it I'll f**k it up so bad nobody can!!
NIX
Tue Apr 26, 2011 11:11 am
abelai wrote:Hows it going? What you up top these days? I'm impressed to see you still have the e30.
Hello mate!! Long time no speak! Will PM you for catch up.
Nick
