mot question indicators
asmith88
Thu Mar 10, 2011 6:21 pm
my mot is on saturday and just came out yesterday morning to find a smashed front indicator lens in the road.
if i have orange bulbs but no lenses? will it be a fail,
struggliong to get a lens in time.
cheers
1990 brilliant red 318 is
harry_p
Thu Mar 10, 2011 6:35 pm
yes it'll still be a fail, you could probably bodge it through with a bit of transparent plastic cut to size and screwed on if you were really desperate.
cheers,
harry
asmith88
Thu Mar 10, 2011 6:56 pm
yea was thinking that, what is the specific mot rul that means i need lenses
Rich_W
Thu Mar 10, 2011 7:02 pm
Not a fail surprisingly! So long as it can be seen from a "reasonable" distance. Definete advise though.
trevski
Thu Mar 10, 2011 7:06 pm
asmith88 wrote:my mot is on saturday and just came out yesterday morning to find a smashed front indicator lens in the road.
cheers
All bulbs need to be defused by way of a difuser or indicator lens !
harry_p
Thu Mar 10, 2011 7:13 pm
Rich_W wrote:Not a fail surprisingly! So long as it can be seen from a "reasonable" distance. Definete advise though.
hmm, i'd have thought it would fail under..
method of inspection,
1. Operate the left and right direction indicators in turn and check
a. that all lamps are present and secure
b. that all lamps are complete, in good working order and clean
Reason for rejection
1. A direction indicator
a. missing or insecure
b. incomplete, not in good working order or not clean, ie so damaged or deteriorated that its function is impaired Note: An effective proprietary repair (eg lens repair tape, etc) must be assessed on its merits considering security, colour, light output and durability
i know one of my metros failed because it had lost the clear outer lens. it didnt affect the light output in any way as they still had an internal diffuser and colour screen which also covered the bulb, but as the lamp was 'incomplete' it failed
surely it can't be that hard to track down an indicator lens at short notice?
cheers,
harry
mattycoops43
Thu Mar 10, 2011 8:31 pm
The general rule with lights, I believe, is that they need to be "as made by the manufacturer", unless it's a legal modification. In other words, parts missing/not working is not good.
1990 325i se "weinrot"-How did they know?
asmith88
Thu Mar 10, 2011 8:51 pm
yea, no breakers nearby have an e30 flip sake, im going to try a specialist tomorrow
beemerbird
Thu Mar 10, 2011 9:49 pm
Do you not know a local Zoner who might lend you one for your test?
colinurquhart
Thu Mar 10, 2011 11:13 pm
Hi mate I have two orange indicator lenses I can post out to you if you want if that's any help.
Colin
m8782538
Fri Mar 11, 2011 10:20 am
I had a car with no indicator lens on the front, passed 3 years in a row at different garages each time.
There is nothing in the MOT that states that the indicator must have a lens, it must be orange and be capable of being seen at a reasonable distance, but no more than that.
only difference i believe is for front and rear fog lights. Fronts must be uncracked and in full working order if fitted otherwise it fails. Same goes for rear fogs.
My mate is an MOT tester so i found out from him.
mattycoops43
Fri Mar 11, 2011 11:03 am
My mot guy told me front fogs didn't matter as they are not a legal requirement.
asmith88
Fri Mar 11, 2011 12:00 pm
somebody also told me that they had 2 mots without lenses and passed,
nah i dont know any local zoners,
hopefully this guy i go to today will have some.
m8782538
Fri Mar 11, 2011 12:42 pm
i know my mate has failed loads of cars on front fogs being cracked as the beam is effected, same as most headlights, that would fail too. unless its a newer car with totally clear glass/plastic and the lenses do not effect the beam of the lights.
Aparently if fogs are fitted they must be in full working order and lenses intact. i had a car fail on it, all i did was removed them and it passed, leave everything else, just remove the units and it passes.
mattycoops43
Fri Mar 11, 2011 12:45 pm
Well, I have been told opposing things by several mot inspector in the past. It seems it is in their hands, and the only thing is you can complain and get a retest from the ministry if you are not happy.
Personally, I don't want to drive a car with anything wrong with it anyway, so i don't really care. if it all works, they can't fail you!
Fri Mar 11, 2011 2:06 pm
The only fog light related items of interest to a UK MOT tester are the rear right fog lamp, its switch and the warning light in the instrument cluster. The rear left fog lamp need not work, and there is no reference at all to front foglights.
The full text of the testers' guide relating to front indicators is given further up this thread, and the only possible reason for rejection in the case in question is that it is incomplete.
asmith88
Sat Mar 12, 2011 3:49 pm
got a piece of acrylic over it for the mot this morning,
passed :cool:
