e34 uj's
Thu Feb 17, 2011 2:03 pm
i have acquired a couple of e34 uj's in case i have any clearance issues with the zaust fanimould with the modded one i have.However,only one will fit to the e36 rack and the other has fine splines also so won't fit the coarse splines on the column :? what's the score here then,i thought x2 e34 uj's were needed with a splined middle jointer so how is it supposed to work that way when only one end fits ???
MrBenn
Thu Feb 17, 2011 2:49 pm
You need to send one of the e34's and your e30 one to Dan and he will combine the two, think he charges about £10 :cool:
Thu Feb 17, 2011 2:59 pm
MrBenn wrote:You need to send one of the e34's and your e30 one to Dan and he will combine the two, think he charges about £10 :cool:
i see :)
325zimmer
Thu Feb 17, 2011 3:38 pm
I've got exactly the same issue, what does he do? Can I do it my self or is it a machine shop job?
leeparkes
Thu Feb 17, 2011 5:16 pm
You can dismantle them yourself.
Pics in Dans link
http://www.e30zone.net/modules.php?name ... &start=100
325zimmer
Thu Feb 17, 2011 5:59 pm
Brilliant thanks!
Thu Feb 17, 2011 9:04 pm
Rather than hammer the caps out that you want to reuse ive found it better to cut them out, hammering can distort the cap and most times it doesnt go back in nice.
Also when pressing them back in dont press on the centre of the cap, this can fck them up also
Dezzy
CR24v it's a lifestyle
Thu Feb 17, 2011 10:18 pm
Mick just send them to Dan. He has done loads. No chance of him fooking them. I know I would have made a pigs ear of it.
You can get the rack fitted up with the front legs. Put the bolts through the bottom with the spacers on top of the rack. Then when the linkage comes back you can just take the drivers side bolt out and slide the rack forward to fit the linkage.
