brake pads
B15NAC
Sun Jan 23, 2011 7:43 pm
whats the best brake pads to use on a e30 for road use? ebc red stuff? :?
cheers neil
ross2009
Sun Jan 23, 2011 7:54 pm
ive got red stuff in mine but aint used it on the rd yet :)
ive heard you have to get abit of heat in them before they start to work ive used green stuff before on a old rs turbo they worked well with up rated discs
monkey
Sun Jan 23, 2011 7:56 pm
Niel i thought standard ferodo pads where fine on my Is :D
B15NAC
Sun Jan 23, 2011 9:17 pm
Yeah I was just wondering how I can make my brakes any better; they're good, but the pedal seems to go down halfway before they start to work! I have a full set of braided hoses ordered, I'm hoping that will help. Any other ideas? :)
ross2009
Sun Jan 23, 2011 9:37 pm
bleed them again may be air in the system
monkey
Mon Jan 24, 2011 6:39 am
you can also adjust the pedal height
B15NAC
Mon Jan 24, 2011 11:33 am
how matt? up behind the glovebox where it goes into the cylinder? :?
monkey
Mon Jan 24, 2011 1:18 pm
B15NAC wrote:how matt? up behind the glovebox where it goes into the cylinder? :?
you can adjust the rod from drivers side , just slacken the lock nut turn the rod to where you want it and lock up the nut . don't over adjust it as you will end up with the brakes binding on .
B15NAC
Mon Jan 24, 2011 3:20 pm
thanks matt will have a look :D
jann
Mon Jan 24, 2011 3:58 pm
Can you do this with the clutch pedal to theres about a 1 inch possibly abit more freeplay until the clutch is actually moving anything?
Jann.
B15NAC
Mon Jan 24, 2011 6:31 pm
I thought the clutch was unadjustable as its hydraulic? :?
e30singh
Mon Jan 24, 2011 8:13 pm
the brake fluid may of been boiled?
