Alpina locks update & pics.....
kieran325
Tue Dec 07, 2010 4:06 pm
I'm after 4 locks for the Alpina centre caps, I heard you can get these from Maplins ?? Is this correct or does anyone have any other suggestions.
Also after the plastic cap that fits over the lock.
Any suggestions and recommendations are most welcome :D
Edit - I have the caps but no locks or the plastic lock cap -
beemerbird
Tue Dec 07, 2010 5:06 pm
Maplins part number CJ14Q looks like it might work. Maplins seem to have redesigned their website, however, so cannot see what size it is :roll:
goosiegander
Zonegoose
Tue Dec 07, 2010 5:15 pm
£98ish for four new locks and keys delivered from the dealers iirc
Sanchez
Tue Dec 07, 2010 5:33 pm
Think I saw a set on ebay yesterday.
kieran325
Tue Dec 07, 2010 5:36 pm
Thanks for that.
alloy wheels direct are £116, I'll try the dealer tomorrow.
Part number is - 3613119
Any idea on the plastic cap that protects the lock ??
Part number - 36 13 109
kieran325
Tue Dec 07, 2010 5:56 pm
beemerbird wrote:Maplins part number CJ14Q looks like it might work. Maplins seem to have redesigned their website, however, so cannot see what size it is :roll:
Thanks :wink:
Anyone tried ?
http://www.maplin.co.uk/Module.aspx?ModuleNo=3029
beemerbird
Tue Dec 07, 2010 6:13 pm
You could also look on uk.rs-online.com and search for 'panel lock'. Wider choice there. In my experience these kinds of locks aren't always key specific, so all locks could be used from one key :wink:
kieran325
Wed Dec 08, 2010 5:02 pm
Just orderd the lock set, lock caps, O rings and the Alpina centre badges from the dealer.
beemerbird
Wed Dec 08, 2010 5:06 pm
Ouch. I hope they used lubricant. 8O
kieran325
Wed Dec 08, 2010 5:13 pm
It's not that bad really, lock set is £95, lock caps are £20 for 4, O rings are £12 for 4 and the badges are £32 for 4 = £160 then my discount.
Oh and 4 new tyres got delivered today too.
Should be picking them up from the refurbers early next week, I've seen them today and looking good.
zaust
Zone day release
Wed Dec 08, 2010 8:03 pm
Phone cooks ferry fella. I bought 4 locks with o rings and key's for less than the above price less 10% .
0208 804 2002
M30 Tech 1 Touring on gas.
kieran325
Wed Dec 08, 2010 8:09 pm
zaust wrote:Phone cooks ferry fella. I bought 4 locks with o rings and key's for less than the above price less 10% .
0208 804 2002
Hmmmm, noted.... I will give them a bell tomorrow :wink:
kieran325
Fri Dec 10, 2010 5:24 pm
Update -
I rang Cooks Ferry, no joy and they would have to order them from the dealer themselves.
A trip to the dealers today and I picked these up -
I need the O ring for the lock caps, bastids :roll:
Here's the lock set up -
I also picked up a cap from the refurbers, can you tell the difference between my original one and the freshly refurbed one -
After fitting the new locks to one cap, I noticed that it didn't fit my 7j alloy, a quick ring to the dealer and I need another lock set for the staggered set, picking them up Tues.
Also had these delivered for the staggered set -
Kos
Fri Dec 10, 2010 11:41 pm
i see the touring is coming in useful :D
www.pukardesigns.com
IG Pukar.Designs
George
Sat Dec 11, 2010 10:06 am
8) (but you knew that already)
darren_mk
Sun Dec 12, 2010 8:51 pm
Thanks for the pictures with the part numbers, will save me looking as i am re-furbing a staggered set i have.
kieran325
Sun Dec 12, 2010 8:57 pm
darren_mk wrote:Thanks for the pictures with the part numbers, will save me looking as i am re-furbing a staggered set i have.
I'm picking up the lock set on Tues for the staggered set, I think it's 91 47 3 613 127 but I will confirm when I get them.
ConnorTreacy
Wed May 04, 2011 2:42 pm
I'm doing something similar to my 16" Softlines. What's a 'staggered set' and how do I know if I have that?
Wed May 04, 2011 2:51 pm
Look inside where the bolts fit, it will say either 7j or 8j,
ConnorTreacy
Wed May 04, 2011 2:54 pm
Cheers, I'll check that when I get home. Does 7 refer to tyre width?
George
Wed May 04, 2011 3:21 pm
ConnorTreacy wrote:I'm doing something similar to my 16" Softlines. What's a 'staggered set' and how do I know if I have that?
I was under the impression that the minimum size of the softlines was 17 inch, as they were introduced on the E36.
Staggered set means larger on the back than the front.
Any pics?
ConnorTreacy
Sat May 07, 2011 7:52 pm
This is interesting, because I thought this too, but the guys at my local BMW dealership kept calling them Softlines.
BadDave
Sat May 07, 2011 8:02 pm
The E30 ones are still regarded as softlines, they just changed the design when for the E36 onwards in 17" and upwards.
There's a rare BBS 2pc split rim known as softline 2 as well
sajad09
Sat May 07, 2011 8:18 pm
This thread helps me alot. Shame i still have to figure out how to remove the caps from wheels without keys.. :x
George
Sun May 08, 2011 4:53 pm
BadDave wrote:The E30 ones are still regarded as softlines, they just changed the design when for the E36 onwards in 17" and upwards.
Are you sure?
The design of the later Softlines is different:
Classics:
In addition, Softlines have the hollow spoke with the valve under the centre cap. Classics (in whatever size) have the valve on the rim edge.
