Has anyone got pictures of an early or late 325 engine?
Adammcf
I need to know whats in my car before I get a replacement engine.
If anyone has any pictures of their engines up close and personal or even better stripped apart it would be great!
My car appears to be a combo of early and late engine parts!
Jimbob
Do you mean the block, internals and head stuff? It's just the location of stuff around the engine like the expansion tank that's visibly different.
http://www.e30zone.co.uk/Jim/piston.jpg
That's an early piston for ya!
dazleeds
- old skool raver
gimme 2mins
www.oldskoolfantasy.co.uk
Turbo-Brown
- Boost Junkie
Off topic, but does anyone else think it's a good idea to remove the sharp edges from early pistons?
dazleeds
- old skool raver
Adammcf
Cheers lads. Daz my engine looks identical to that one so it appears I have a late block after all.
I cant tell from those pics though how much difference there is between the early and late pistons.
Maybe mine are the late ones and they just look like the early ones in the pic. Is there a code number stamped on to the pistons?
The mystery deepens.
Adammcf
Come on peeps, keep those pics coming in!
jonb
adam
they are early domed pistons. the late pistons are totally different. they have raised parts in the middle of the crown.
you can fit an early or late engine into your car. it doesnt matter.
if your getting hold of an early engine, you will need to change the waterpump, front pulley, front timing cover, injector loom, and thats about it. all these will be taken off your existing engine, as these have been fitted to make your early engine compatable with your late motronic.
Adammcf
Havent found any engines yet but I just wanted to make sure I dont end up with something that wont be compatible with the car.
Keep the info coming folks, its all greatly appreciated.
jonb
adam
if you purchase a 2.5 engine it will be compatable with your car, no matter what age. so uve no need to worry.
Adammcf
I take it the same applies if I just get a replacement bottom end? Just change over the pulleys, covers and pump etc?
Dont suppose you have any yet? lol
jonb
adam
i dont im afraid. but yes, thats all you will have to do.
Turbo-Brown
- Boost Junkie
I smell something I've missed herejonb wrote:adam
Why do you need to change the waterpump and timing cover?
I've just fitted the later toothed front pulley and sensor bracket to mine.
Templ8e30
The water pumps are different for motronic/l-jetronic engines.9
The late type has 1 exit tube whereas the late typ has a second exit tube cast at 90 degrees to the first.
The later cars had a slightly different cooling system you see
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Turbo-Brown
- Boost Junkie
Oh, that's not so bad then. Think I'll survive with the old system
jonb
temple8 is right
but the early crome bumper turds had the expansion tank on the offside. so they had an extra outlet on the pump which went to the tank. where as later plastic cars had it on the nearside. you can just blank the tube off if you like, but this is a bit of a bodge.
the later timming covers has a provision for the timing sensor wire to hold onto. which stops it fowling against the water pump pulley, and burning through the insualtion.
Adammcf
Cool, as long as everything can be bolted off one and onto the other I'll be happy.
