CATALYST!
anderls
Post Wed Sep 28, 2005 8:03 am
Hey forum.....is is possible to just "disconnect" the catalyst? Without to many problems!!
What can happen if you buy a car with a G-kat and decide to take it of and install "normal" pipes?
johnono
Post Wed Sep 28, 2005 8:06 am
Ԛ´morn du ;)
jo det kan man godt!
skriver jeg pm til :cool:
anderls
Post Wed Sep 28, 2005 8:11 am
Dav Johnono...manner tidligt oppe!!
Ok....I still have to get rid of my old 320 and "upgrade" to 325....
(Admin...Where did all my posts go?)
johnono
Post Wed Sep 28, 2005 8:20 am
frisk! ;)
Men Nej!! du kan sagtens med den 20 du har, det skal bare omlaves LIDT!! men mega lidt! :thumb:
Har lige sndt pm, kik og se, hvis du mangler noget, bare skriv :cool:
Templ8e30
Post Wed Sep 28, 2005 8:42 am
'kin ell boys :mad:
Dunno if Johnono has answered this but yes you can just discoonect the lambda sensor and bin the cat.
There is a wiring loom socket underneath the battery tray under the bonnet, twist the connector off and remove the sensor. All cat prepared cars have a plastic cap attached to this socket to prevent corrosion, would be a good idea to raid a breakers yard for one.
The ECU will the run in open loop and you may even get a bit more 'poke'.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
johnono
Post Wed Sep 28, 2005 8:50 am
:teehee: yea, i did in a pm, too much danish first thing in the mornin :lol:
but pretty much said the same as u iain :) would he need a non cat chip or not?
Templ8e30
Post Wed Sep 28, 2005 10:08 am
Johnono, thought you might have :D
The standard ECU and chip will work fine with/without the lambda sensor, no worries there mate :cool:
Cheers,
Iain T
johnono
Post Wed Sep 28, 2005 10:13 am
top man, cheers iain ;)
