Anybody know about O Rings??
mikey75
Wed Sep 15, 2010 6:55 pm
Need to replace the O Ring on the oil level sensor, went to BMW but this part is no longer available. Shouldn't be too difficult to get hold of one but need to know which size (don't want to have to take the sensor off then go hunting for one!). It says on Real OEM that it is 3 x42,3
If I go to a supplier will they know what this means? what does the last 3 mean?
Rich_W
Wed Sep 15, 2010 7:14 pm
3mm x 42.3mm. Don't ask me why the Germans use a comma instead of a point.
So thickness x diameter.
Wed Sep 15, 2010 7:16 pm
Check out an engineering supply company and they will have what you need mate. :D
mikey75
Wed Sep 15, 2010 7:18 pm
Thanks guys, I'll get this sorted out this week.
Wed Sep 15, 2010 7:19 pm
Rich_W wrote:3mm x 42.3mm. Don't ask me why the Germans use a comma instead of a point.
On most CNC machines you can specify a "point" or a "commer" .
I think it stems from way before the "decimal point" was invented.
:o: :o: :o:
Night.
Wed Sep 15, 2010 9:03 pm
Make sure you get one made from oil resistant material. Not all O rings are.
mikey75
Wed Sep 15, 2010 9:08 pm
Thanks, will do
Wed Sep 15, 2010 9:10 pm
Brianmoooore wrote:Make sure you get one made from oil resistant material. Not all O rings are.
Especially those supplied by BMW with their vanos units :)
