where can i get a clutch kit for bmw e30 320 cab
- BadMoonRising
Eurocar parts?
GSF or Euro Car Parts, but get the decent best quality item, which hopefully will be a Sachs or Luk.
Sachs are OEM part but without the BMW sticker on
better of getting the whole kit thenpenton08 wrote:gsf do a sachs clutch kit for about £120 all in, the only place you will get a release bearing alone is from the bmw dealers. iirc they where about £70.
HairyScreech
yeah a 325 one will do the job and can be cheaper, mine was £30 less if i got a 325 one.
- Cypriotgeeza
you could do but for the amount of hassle of getting the box off and while you actually have the box off you'd be better off with a fresh clutch in there too!BMWE30325 wrote:could i buy just the clutch release bearing ??
Check my M30 build threads:
HairyScreech
and if the pressure plate and friction plate are ok then put them aside for emergency spares, its one thing that can just go and leave you buggered.
