what are these off?and some front billy's???
Sun Aug 15, 2010 7:49 pm
these were in the boot of an e30 i bought a while ago.
they look very much like e30 ones but not identical :?
any-one know?
the faded ones are e30.look at the pointed part...it's smaller.
i've also got these and i'm not 100% sure they are e30 ones
these are bmw ones and the part number is. well i can see two lots of numbers and they read, 4470127w*0 and 3132-11274872 any help on these lads ?
toby
Sun Aug 15, 2010 7:53 pm
I'm guessing E34. Is there a part number on it?
Barx325i
Sun Aug 15, 2010 7:56 pm
looking very e34
Possibly E28.
zaust
Zone day release
Sun Aug 15, 2010 8:05 pm
E32 is a likley one.
M30 Tech 1 Touring on gas.
cecotto479
Caution Unreliable Seller
Sun Aug 15, 2010 8:11 pm
E28.
1981 E23 735i
gatesy23
Sun Aug 15, 2010 8:14 pm
E34
Sun Aug 15, 2010 8:18 pm
wow you lot must be bored tonight :D
ok i've gone and dug them out again for the part number.there is one on the mirror plastics that i can't read and one on the rubber bung that hides the wires i can and it's this
006193 there is a big circle with E6 inside on the same part.
toby
Sun Aug 15, 2010 8:23 pm
Well just go back to the car you nicked 'em off and have a look? (Joking!)
cecotto479
Sun Aug 15, 2010 8:40 pm
I'm changing my mind. E34. The wiring plug isn't right for E28.
1981 E23 735i
Sun Aug 15, 2010 9:04 pm
any help with the billys guys
Sun Aug 15, 2010 9:45 pm
billys look like B8's
Sun Aug 15, 2010 9:51 pm
can anyone get the link for the b4-b6 thread.
i tried a search but it said no topics or posts match :?
Sun Aug 15, 2010 9:57 pm
you need my picture!
Sun Aug 15, 2010 10:01 pm
Measure the diameter of the struts, and the overall length
Mirrors are E34, without a doubt
Sun Aug 15, 2010 10:36 pm
exactly 2ft from the bottom to the very top most part of the nut.[pic]
diameter is 37mm. :?
^^^no allen key hole?
if i measure to the top of the shiny bit it's 550 mm and the yellow part is 430mm
Sun Aug 15, 2010 10:43 pm
could be a B6 now, have you got a stock boge damper there? B6 is alot shorter but a B8 is the same length as a boge
Sun Aug 15, 2010 10:44 pm
only have these si :(
cheers for the help on the mirrors lads.
