Tappets on my 325
320stu
Tue Jun 15, 2010 11:11 am
2 questions, Can the tappets on my 88 325i touring be adjusted? as they are bit noisey, and 2nd is there any one on the site local to west sussex that could do them for me??
Thanks Stu
unmol
Tue Jun 15, 2010 12:14 pm
There quite easy to do, jus need the rocker cover off and a feeler gauge. There a thread on it in e30 zone wiki.
god-father88
Tue Jun 15, 2010 1:06 pm
mate if you can't do them yourself! don't even try it! your fook up ur engine!..take it from someone whos tried! haha! 8O
320stu
Tue Jun 15, 2010 6:44 pm
I dont think I'll try it myself then!
Anyone want to earn a bit of cash and do them for me??? Please!!
craigieeb
Tue Jun 15, 2010 6:58 pm
If you follow this guide, you can't really go wrong,
the job sounds bigger than it is
http://www.e30zone.net/e30zonewiki/inde ... M20_engine
Tue Jun 15, 2010 7:20 pm
god-father88 wrote:mate if you can't do them yourself! don't even try it! your fook up ur engine!..take it from someone whos tried! haha! 8O
How can you f*ck up an engine by getting the valve clearances wrong? Is this the same experience that told you that blue smoke on start up was head gasket? :roll:
http://www.e30zone.net/modules.php?name ... c&t=171983
Set them too tight and it'll run rough. Set them too loose and it'll sound like a bag of spanners.
To the OP, unless you get stuck in, then you'll never learn. Read the wiki and have a go. Take your time and be methodical. You can do it.
320stu
Tue Jun 15, 2010 7:25 pm
Cheers B7, Like you said if you dont give it a go I'll never learn
Daddycoo1est
Tue Jun 15, 2010 9:45 pm
To the OP, unless you get stuck in, then you'll never learn. Read the wiki and have a go. Take your time and be methodical. You can do it. [/quote]
Very easily if you tighten the rocker nut too much like a few people I know have in the past, especially the one who's rocker then snapped at 130mph :mad:
b17
Tue Jun 15, 2010 10:06 pm
This may sound like a silly question :o: but the wiki talks of turning the crankshaft with a 22mm socket and ratchet until the cam is in the right position. Does this mean I need to expose the cambelt as I need to try the same?
Tue Jun 15, 2010 10:10 pm
b17 wrote:This may sound like a silly question :o: but the wiki talks of turning the crankshaft with a 22mm socket and ratchet until the cam is in the right position. Does this mean I need to expose the cambelt as I need to try the same?
No the 22mm is the crank shaft pulley bolt.
Tue Jun 15, 2010 10:12 pm
Daddycoo1est wrote:How can you f*ck up an engine by getting the valve clearances wrong? Is this the same experience that told you that blue smoke on start up was head gasket? :roll:
Very easily if you tighten the rocker nut too much like a few people I know have in the past, especially the one who's rocker then snapped at 130mph :mad:[/quote]
I've never seen that. The concentric nut only needs to be nipped up. All the snapped rockers I've seen have been cheap after market ones that have gone miles away from the adjuster. I'd say you'd have to go some to overtighter one of these.
Daddycoo1est
Tue Jun 15, 2010 10:15 pm
Some people think they need tightening to the max though lol
b17
Tue Jun 15, 2010 10:16 pm
Cheers B7 - may give mine a try to sort my eternal flat spot!
Longman325Touring
Wed Jun 16, 2010 1:51 pm
Don't feck about trying to turn the crankshaft, the easiest thing to do is jack up one side of the car at the rear and with the car in gear turn the free wheel to rotate the engine. So much easier than jacking the front up, removing the undertray and losing the skin on your knuckles trying to rotate the crank.
Stu, I live in West Sussex and have done this before so if you'd like a bit of help I don't mind popping along to your pub one weekend.
craigieeb
Wed Jun 16, 2010 2:27 pm
Unless you have a slipper..
and you can turn the crank from the top side of the car, you don't need to remove the under tray
Longman325Touring
Wed Jun 16, 2010 2:50 pm
craigieeb wrote: Unless you have a slipper..
Sorry, forgot to mention about the slipper!
sideshowbob
Wed Jun 16, 2010 2:57 pm
Need to adjust tappets on my 325i convertible, it has an air con radiator that reduces the gap between the radiator and crank nut to a point where you can't get a spanner onto the nut. I don't think jacking up a rear wheel and turning the engine over that way with an auto box will work.
Other suggestion was take out spark plugs and jog the engine over on the starter motor, can't see that being easy trying to judge position of cam/valve from sitting in drivers seat and turning ignition key....any other ideas
320stu
Wed Jun 16, 2010 7:48 pm
I have air con as well
ross_jsy
Wed Jun 16, 2010 7:58 pm
Daddycoo1est wrote:Very easily if you tighten the rocker nut too much like a few people I know have in the past, especially the one who's rocker then snapped at 130mph :mad:
If you tightened it that much, the engine is going to run like shite and produce almost no power, let alone enough to do 130. Fully tightened the valves will never close....
Daddycoo1est
Thu Jun 17, 2010 5:10 pm
They over tightened the securing nut which weakend the rocker causing it to snap, the tightness of the nut wouldn't effect the running of the car
zinderz
Thu Jun 17, 2010 5:40 pm
sideshowbob wrote:Need to adjust tappets on my 325i convertible, it has an air con radiator that reduces the gap between the radiator and crank nut to a point where you can't get a spanner onto the nut. I don't think jacking up a rear wheel and turning the engine over that way with an auto box will work.
I once did this with the help of Hong Kong Phooey (a fellow zoner). Was fine turning it over with the starter motor sideshowbob. Just turn it a tiny amount on the key at a time.
Tech 1.. Old School Cool
