Heater dial differences (like in Demlotcrew's)
William
- Location: Home:Suffolk, Uni: Cirencester, Gloucestershire
smithy318i
Some came with the dial for temerature controlled heating. The dome shaped button above the dial is where the sensor goes. even if you have numbers, this doesnt mean you have the temp regulator.
Demlotcrew
There are more than one sensors.smithy318i wrote:Some came with the dial for temerature controlled heating. The dome shaped button above the dial is where the sensor goes. even if you have numbers, this doesnt mean you have the temp regulator.
A
A1BMW325iSport
i`ve fitted the numbered dial
looks much better
looks much better
