bhp
player6
Post Sat Sep 10, 2005 1:05 pm
what is the most bhp you can get out off a m20
scot 328i with 260bhp
eun
Post Sat Sep 10, 2005 1:10 pm
depends how rich you are :lol:
anything is possible nowadays as long as you've
got the budget to fund it! :)
Zayyan
Post Sat Sep 10, 2005 1:11 pm
I've no idea but I'd like a guess.....220-230 N/A?
tomstickland
Post Sat Sep 10, 2005 1:23 pm
Without Nitrous Oxide or turbochargers, then you're limited to around 80lb-ft/L, so high rpm is the only way to get high BHP. The limiting factor will be the flow limit of the inlet valves in the head, assuming that throttle bodies are used so there are minimum inlet tract restrictions.
As a rough indication, a decent 2L 16v engine can manage 200-210BHP in sensible tune, and in touring car spec they managed 250BHP.
A useful number is the bmep (brake mean effective presure) which is the engine power per litre divided by the rpm at which that power is made.
ie in silly units it's BHP per litre rpm. Since rpm mutliplied by engine capacity indicated an air flow rate, the bmep is the power per unit air flow. This number is pretty much a constant for normally aspirated engines in the same state of tune.
This is something I wrote up a few months ago on power: http://www.tomstickland.co.uk/astra/hom ... _stats.htm
astondg
Post Sun Sep 11, 2005 12:30 am
Some good info there.
tomstickland wrote:As a rough indication, a decent 2L 16v engine can manage 200-210BHP in sensible tune, and in touring car spec they managed 250BHP.
The touring cars are usually 260bhp to 275bhp.
Aston
BMW E30 323i with some stuff
1:21.67 @ Morgan Park Raceway
