Are M20's known to use a bit of oil? Mine's doing 1L every 1600 miles on average. Power is still good and mpg too. No signs of blue smoke etc so the engine really isn't that bad, it just seems to use a bit of oil.
Any thoughts?
Oil consumption
HairyScreech
probably leaking rather than burning it up.
Most likely a leak but if you say it doesnt leave stains on the drive then maybe its burning it through worn rings or valve stem seals.
How many miles has it done.
HairyScreech
mine leaks a bit, you can find it wet around the block but it never leaves patches, the loss will happen when its running and hot, at higher oil pressures, so you will only leak on a run, when your still on the drive at idle you wont leak.
SeymourCake
where are the usual places to find leakages?
HairyScreech
front of the block from either the cam seal (like mine) or the crank seal or the plastic bungs in the head, back of the block from the crank seal or plastic bungs.
I have found after 10+ years of ownership of e30 327i that oil use is somewhat related to the speed the car is driven at and the weight of oil that is used. Generally I will use about 1/2 a litre in 10,000kms. If the oil is say 5-40 synth it will use more than 15-50 synth over the same milage period.
Anyway.....1 litre in 2,000kms sounds too much. Check compression of the cylinders and if you have a few pots that are low check if its the head or rings. If its the head is a much easier fix.
I was wondering about rings/stem seals but usually you'd see a bit of blue smoke and I'm getting none at all (that I can tell). Probably just leaking a bit as it is wet down there.bss325i wrote:Most likely a leak but if you say it doesnt leave stains on the drive then maybe its burning it through worn rings or valve stem seals.
It's on 107k miles.
TBH I'm quite tempted just to bin the B20 in favour of a B25 and have an extra 40bhp to boot. Best excuse I can think of for power upgrades! Although the more I think about it the more I think it's just a leak rather than actually losing oil. The sump guard is quite wet...jermyns wrote: Check compression of the cylinders and if you have a few pots that are low check if its the head or rings. If its the head is a much easier fix.
HairyScreech
in that case clean the front of the engine off with some break cleaner and see if it comes back.
