some one tried to steel my car
bluey
Sat May 01, 2010 10:24 pm
i noticed today someone tried to steel my car last night,the drivers lock is hanging out and very very loose,can pull it almost all the way out,the bit where the key go's dosent look damaged and the key still gos in but the whole lock turns.
wondering if anyone knows what the damage could be and where i can buy the bits to fix it before i take the door card off,
i hate scum :x
thanks
Sat May 01, 2010 10:30 pm
Sounds like they have just tried to lever out the lock barrel.
Is the door damaged around the hole where the barrel fits?
The barrel is held in place by a C shaped thin metal clip that slots in the other side of the door skin. So you'll have to remove the door card to access the inside of the door.
The c clip will probably be sitting at the bottom of the door. You may be lucky and get away with just putting the lock back in place and securing with the c clip.
Can you still put your key in the lock barrel and turn it?
Norwich normally ain't a bad place. Do you live on the Larkman? :P
TheHeap
Maybe it's just the C clip on the back that has come off
bluey
Sat May 01, 2010 10:35 pm
how did you guess lol Larkman is yours the white one or black estate going round :).theres a couple e30's around this area.
thanks for the advice ill got the door card off and search for the clip.
mines the low one that scrapes on evey speed bump lol
**BANNED**
Sat May 01, 2010 10:36 pm
Sounds like the 'U' shaped spring clip has broken or dropped off.
You will have to get the door card off anyway,you may just get lucky and find the clip in the door bottom.
Lock needs to be fed in through the door skin and an alloy bracket that supports a micro switch for the dead lock,fiddly to do,but it goes in eventualy with a little patence,then the clip slides on to keep all secure.
There's a chance that the lock barrel could be damaged,it should have an arm on it to operate the locking gear,this can break off...best fix is either a s/h lock set or a 'barrel repair kit' from the stealer at about £20.
Youth is wasted on the young.
burtcocain
Sat May 01, 2010 10:38 pm
lock set on e-bay at the mo.........
burtcocain
Sat May 01, 2010 10:39 pm
bluey
the key go's in and i can turn it,its quite stiff but it wont unlock the door, :(
Grrrmachine
E30 Zone Wiki / Team Member
Sun May 02, 2010 8:56 am
This thread is pretty picture-intense, but there's some great photos of the C-clip everyone's talking about.
http://www.e30zone.net/modules.php?name ... ic&t=47699
I used all the advice there to change the locks on my E30, and while it's a pain in the arse (probing through the door skin with two long screwdrivers like chopsticks) it's do-able.
bluey
Sun May 02, 2010 9:51 am
thanks for the link its a great help..
Grrrmachine
Sun May 02, 2010 10:40 am
I'm working on a door right now; I'll see if I can get a pic of it in situ from the inside for you. Fingers crossed...
Sun May 02, 2010 10:52 am
it's right fiddly job getting that back on.
k13
Sun May 02, 2010 12:01 pm
oh yes definetly a riddly job fitting the C-clip. just undo few bolts to get ther window mechanisms loose to get to the lock from inside.
ask the seller of the lock sets on ebay if they are fully working especailly the driver side due to 20 years of wear and tear the arm inside could be broken and will not lock or unlock properly. same situtation i had with my lock set off ebay and it was my 2nd lock set i ordered off ebay as the 1st lock set had a snapped lock arm just like the 2nd lock set so then JB WELD glue came in hand , its 2 glue sticks that you mix together and it sticks like as if youve done a weld job and all i did was just glue the rotary arm together and now its solid as anything otherwise i wouldve been stranded with a 2nd set of locks LOL.
Grrrmachine
Sun May 02, 2010 12:05 pm
I knew keeping bookmarks was a good idea :)
http://e30world.com/body/BMW-E30-lock-cylinder-repair
Once you've got the barrel in your hands, this is how to take it apart and rebuild it.
