Need Power
Waste of pennies. Really, really, really avoid spending silly money mate.
Daimlerman said straight away in your last thread concentrate on the handling, which isn't as much of a waste.
A lot of engines follow the same principles for tuning. Make air go in easier and exhaust go out better. Force air in (charging). Or changing profiles/ratio's and whatnot of internals to change powerbands and prolong them or whatever.
You could spend thousands on a M40 only to still be slower than a shitter of a 325i.
My advice, if your serious, is to rebuild a 318i cylinder head (not that difficult) which if you find a reasonable one in the first place will not cost too much. Then give your car new filters, oils and a good check over. Then a chip/remap. Finally an induction kit, a manifold and exhaust. Probably looking at somewhat £1000 and 10/15 more bhp.
A camshaft will just raise the powerband or prolong it etc. It wont make your car go faster. Induction kits and manifolds wont really do anything if the engine is stock, and still full of 20 years of wear and tear.
A chip is your best bit to get on its own. £30.
Handling though, every part will improve your car as much as it would to any other E30.
Uni is killing the project.
thanks for the help will.
i'm not doing a swap because no one keeps the little old 1.8
i have had a 3.5 m30 e30 good fun
but wanna finde out first hand why every one just takes the m40 out
i know it's not a good engine but will give it a go any way
- murran
face facts its just slow! get used to it or pull the engine out..... m42 it.
e21 killing tyres with e30 325 powerzzz
drifting on the cheap......... www.trampdrift.com
e21zone........ www.bmwe21.net
- Kos
- Contact:
piper do a cam for it
bigger TB and maybe an exhuast will help a bit
thats it for bolt on/in bits.
you could get 130ish bhp out of it with relative ease, but if you want to be a hero i dont see why 180bhp will not be possible but it will cost a fair bit in terms of head work and ITB's
i think Lester owen has had 2.0 M10's making brutal ammounts of power !!
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
chu346 had a turboed M40 running on megasquirt that had been dynoed at 190bhp and it was very nippy. He was selling it as a complete conversion before christmas, he may still have it?
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
