cutting springs on an e30
dude, why don't you measure your ride height and then work out how much you want to drop it by and then work out what spring drop you want and then buy the appropriate springs?
Cut springs is as pikey as it gets
What do you intend to use the car for?dt520 wrote:the car is'nt on the road its in my garage.
can you buy any 80 mm springs or are 60 lowest apart from coilovers
If it is a road car, it will be horrible in the handling dept with 80mm drop as there's basically no suspension travel left. As soon as you drop a car it will also highlight any tired and worn out suspension bushes.
As said above mate this forum on the most part is for people who enjoy driving and owning E30.
Try asking the drifters they might be able to weld your diff at the same time, Actually i have seen a thread with welded spring as well. Maybe they will be along soon but be warned its a LIFESTYLE
Bob_S wrote:Your an animal.. a complete butcher. Leave the sodding thing alone and buy a corsa and conduct your activities on that
Bob_S
don't forget to cut the rear panel out for a big of fast action diff welding!DanThe wrote:Paint the bonnet matt black, trash the front valance, kill the engine, fit steelies
Bollocks to this 24v scrap!
- Kos
- Contact:
cutting a coil is not that bad, well its not as bad as using a blow torch to heat them down to the desired hight
aparently e24's respone well to having a coil cut off
ps, rear springs are pig tailed to cant really be cut, if you do then you are a butcher
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
- Kos
- Contact:
DanThe wrote:Would it be better if they were cut and then had the pig tails welded back on?
10 out of 10 for effort though dan
IG Pukar.Designs
IG Pukar.Designs
- Kos
- Contact:
no way ? i'm speachless !!DanThe wrote:Kos, im sure its been done before..
IG Pukar.Designs
IG Pukar.Designs
sweep wrote:With a gasless mig.
Ha ha they are sh!te arnt they.
Where are all the tramps. Normally good for a bit of advice on these matters
- Kos
- Contact:
fixing their carsDezzy wrote:sweep wrote:With a gasless mig.
IG Pukar.Designs
IG Pukar.Designs
edited KosKos wrote:f*ckng their carsDezzy wrote:sweep wrote:With a gasless mig.
Here you go half way down. It's a lifestlye car
http://www.e30zone.net/modules.php?name ... &start=175
- Contact:
Its friday night boys, they will be out diffin on tescos or cruzin McdonaldsKos wrote:fixing their carsDezzy wrote:sweep wrote:With a gasless mig.
- Kos
- Contact:
ha ha ha
we should so have meet in maccy d's some time
IG Pukar.Designs
IG Pukar.Designs
