Hello boys, are the exhaust's from the down pipe back the same on a 325i as a 320i, got a 320i and have seen a pipe for sale, it only has the back box, will it be too loud????????
Mitch
320i-325i exhaust
koos
Davenotouring
You need to check if you have the two, or three piece system up to the manifold to downpipe flange.
Also, it will only fit if yours has a twin pipe system.
Good luck!
Shouldn't be much noise difference between a 325/320 exhaust. The manifolds are the same anyway.
Good luck!
BMW 328i Cab - Daily Slag
mrLEE30
on mine the manifolds are the same, but the 325 exhaust is a larger diameter then the 320 right up to the silencer. thus to fit a full 325 system on a 320 is ok, but to mix and match may require reducers or some bodged cutting! you can see below the difference in diameter of the silencer tail pipes, this same difference in diameter is up to the manifold.Also worth noting that by putting a 325 exhaust on a 320 the exhaust note will not be as bassy due to the larger diameter, it will not be any louder.
mrlee
mrlee
koos
my bad, its a free flow, no middle box, straight through pipe from down pipe to the back box. Will it be too loud? Its a powerflow.
