Raising my suspension
- oos_ya_daddy
Hi. Anyone know of a way I can jack up the suspension on my E30. Need it raised up for extra clearance over the exhaust etc on a rally !
No one knows of a drop mount kit or anything similar ?
Spring assisters will help raise it a bit but will also stiffen too
http://cgi.ebay.co.uk/COIL-SPRING-ASSIS ... 19b8a5787c
How would you need it higher than standard?!? they are like tractors on standard height although they are quite soft and wooly.
Must be pretty deep tram-lines your going down!
- oos_ya_daddy
Thats pretty much it ! Its a 24hr indurance trial on farmers tracks and green lanes. Mostly up very steep hills. You have to be going very fast to get up most of them and underbody clearance is essential. I plate over the exhaust etc but wanted to get a bit more height if possible ? I tried spring assisters last time but they fell out during the rally ! Ill probably use them again but cable tie then in or something ?
Cheers !
Cheers !
Why not go to Faulkner and get custom springs made? I'm sure they're not massively expensive.
http://www.dfaulknersprings.com/
how much have you got to spend?
i'm sure gaz would be able to custom make some coilovers with longer dampers and longer softer springs than usual.
at the rear you could probably get some spacers made up to sit under the standard rear springs and some custom made longer front springs
cheers,
harry
harry
- oos_ya_daddy
Yeh thats it. I am doing the MCC Trial. Dont really wanna spend much. I normally do it in a 205gti but thought id try rear wheel drive this time. If it performs well ill keep it for other events. Ill see what I can get. Cheers for the assistance.
- oos_ya_daddy
can e34/e28 5 series springs be fitted i wonder ?
Longer springs and longer dampers. You can get custom springs made pretty cheap from some places, had one of our customers recommend someone to me, but can't remember who for the life of me!
Rear dampers are easy - we can custom make telescopics upto 24" long. (£65+ VAT each btw)
Fronts will be tricky though, no idea where you'd get inserts with a longer piston rod...
Could you cut and extend the strut and put a spacer the same size under the damper? You wouldn't get any more travel as the rods would be the same length, but you would get mote clearance.
Actually couldn't you do that anyway, cut under the spring platform, extend the leg with some tube, weld it all back up and put a bung or spacer under the damper so it still sat tight to the top of the strut.
cheers,
harry
harry
a e30 on standard springs has got to be better than the snake oh i mean MGoos_ya_daddy wrote:Yeh thats it. I am doing the MCC Trial. Dont really wanna spend much. I normally do it in a 205gti but thought id try rear wheel drive this time. If it performs well ill keep it for other events. Ill see what I can get. Cheers for the assistance.
what engine are you using?
- oos_ya_daddy
I think thats exactly what I will do, having had a bit of a closer look last night. A bit like the drop mount kits you can buy for 4x4s. Basically just move the whole arangement further away from the body.
Thanks guys. Love the pics !
