bmw mini wheels
e30_318i
Post Fri Aug 19, 2005 5:09 pm
will these wheels fit on our beloved e30's?
if so ive seen a ?euro? style wheel on ebay for sael which could look good on an e30
http://cgi.ebay.co.uk/BMW-MINI-ALLOY-WH ... dZViewItem[/url]
TOURINGDADDY
Post Fri Aug 19, 2005 5:13 pm
ask the seller if the eta is 4*100 and the off set needs to b between 25-35 then they will fit if not then no they wont
e30_318i
Post Fri Aug 19, 2005 5:15 pm
what other wheels will fit e.g vauhall
TOURINGDADDY
Post Fri Aug 19, 2005 5:17 pm
vauxhall will fit but u need to check the offset as above needs to b between 25-35 or they wont fit properly :D
e30_318i
Post Fri Aug 19, 2005 5:19 pm
cheers mac daddy
i know what to look for now when im buying sum wheels! i hate 14inch bottle tops
Sjoerd320i
Post Fri Aug 19, 2005 5:32 pm
TOURINGDADDY wrote:ask the seller if the eta is 4*100 and the off set needs to b between 25-35 then they will fit if not then no they wont
you mean et? et is ofset
bolt patern should be 4x100
ian332isport
Some VW wheels are also 4x100, but normally around 35mm offset.
Ian.
TOURINGDADDY
Post Fri Aug 19, 2005 5:35 pm
yeah ment pcd not eta :oops:
Jos
Post Sun Aug 21, 2005 3:29 pm
Also need to check your centrebore, I think the Mini is the same as the e30 anyway, 57.1mm
'94 e36 tree climber
BrAdZ
Post Sun Aug 21, 2005 6:24 pm
what can you get away with spacers? if i put spacers on a wheel would it make it a higher offset?
what i mean is ould i buy some wheels wih an et20 and make them et35 with a spacer?
Jos
Post Sun Aug 21, 2005 6:54 pm
Spacers reduce offset, not increase it so you can't go from ET20 to ET35, but you could do it round the other way
astondg
Post Mon Aug 22, 2005 1:33 am
ian332isport wrote:Some VW wheels are also 4x100, but normally around 35mm offset.
Ian.
I have had to use some Volkswagen Golf wheels on my 323i before. They had a 20 to 25 offset, I can't remember exactly. I don't think they were standard Golf wheels though, just ones that had been on a Golf.
Aston
BMW E30 323i with some stuff
1:21.67 @ Morgan Park Raceway
Hyperion
Post Mon Aug 22, 2005 9:07 am
This whole wheel thing can get pretty confusing. What gets me is that the car has a 25 offset but you can fit wheels up to a 35 offset, right?
But then you will need spacers etc.....
