M20 2.7 Conversion Info/advice/help/project ideas please
Dan318-is
Post Thu Aug 18, 2005 9:40 pm
recently acquired an early m20 engine for college and am rebuilding it, anyone got any ideas of what i could do it in the way of 2.7 conversions, or just bolt on a newer head? experiences or recommendations ??
im not that full of knowledge on the m20s i dont no much about them and any ideas of a good project would be much appreciated
iv got about 40 hours worth during the year to do it at least
and a limited amount of money so no forced induction lol. any ideas lads?
jay528ise1985
Post Thu Aug 18, 2005 9:46 pm
What capacity M20 is it? 2.0, 2.3, 2.5 or 2.7?
1989 BMW 320i 2.7 2 door saloon
Dan318-is
Post Thu Aug 18, 2005 9:47 pm
2.5 block fella
Sjoerd320i
Post Thu Aug 18, 2005 10:21 pm
tell me if you need a diesel crank ( handles high revs beter than eta )
and help the guy out lads, Karan, Jimbob etc :D :D
E30Adam
Post Thu Aug 18, 2005 10:22 pm
Do a search mate, there is plenty to find on the forum about the 2.7 conversion.
Dan318-is
Post Thu Aug 18, 2005 10:27 pm
cheers adam
Post Thu Aug 18, 2005 10:33 pm
The joys of the 2.7 is u can go a good few ways about it. As u can use all different parts of various M20 engines!
This is what i know so i'll try my best!
one thing u need for all of them is the crank out of an E28 525e (eta engine) which in this country only came as autos. Or if your really lucky a euro only 324d crank which alpina used.
U can use a 2.5 block,eta block, or have a 320 block bored out
conrods the shorter 2.0 or eta rods, 2.5's are too long
2.0 or 2.5 heads, but if u can only use a 2.0 head with an eta block anyone? (Easy 2.7 is eta bottom end with 2.0 head)
325 pistons chrome or facelift ones, 2.0 too small, and eta are wrong for some reason
theres alot more to it but this should help?!
Dan318-is
Post Thu Aug 18, 2005 10:51 pm
gr8 help
what sorta cash for those parts considering i alreayd have a 325i??
hjow much power at the end?
Post Thu Aug 18, 2005 10:58 pm
as u have the best engine to start with for performance u would need
eta crank
320 rods
in theory this is all to build a basic 2.7
but the block will need to be decked about 1.5mm and a verney pulley fitted to adjust the timing and an appropriate chip
powr depends on what u use, how it's run in, performance mods along the way, how deep are your pockets!!!
M5pilot
Post Thu Aug 18, 2005 10:59 pm
This topic has been so discussed that everyone on here is an expert now!
Defo try using a TD Steel crank for starters.
Get the compression nice and high. Buying custom pistons for this might prove to be quite expensive so the next best alternative is early 325i pistons.
The last two cars built using this method have both shown to break the 200BHP barrier with ease. Those being Quaser's engine and Jimbob's engine.
Dan318-is
Post Thu Aug 18, 2005 11:01 pm
pockets not that deep
got early 325i pistons already
how much are pulleys?
deck the block?? WTF?
Sjoerd320i
Post Thu Aug 18, 2005 11:06 pm
deckin the block is done by a thicker gasget IIRC
Karan
Post Thu Aug 18, 2005 11:08 pm
329iturbo wrote:deckin the block is done by a thicker gasget IIRC
no.... u have to shave metal off the top of the head
Dan318-is
cylinder head?
how much
Sjoerd320i
Post Thu Aug 18, 2005 11:09 pm
thought that's called skimming (spell)
Dan318-is
Post Thu Aug 18, 2005 11:10 pm
:yeahthat:
Karan
Post Thu Aug 18, 2005 11:18 pm
sorry i meant block.....
decking i believe is shaving a layer of the block itself!
Karan
Widge
Post Thu Aug 18, 2005 11:20 pm
Guys, guys guys.....
DECKING :- (vrb) To shave off material from the top of a cylinder block, commonly used when using 320/eta con rods with 2.5 pistons, as they will be approx 3mm too far down the bores.
SKIMMING :- used to take a tiny amount ie thousanths of an inch off a head to increas compression or straighten a warp.
DECOMPRESSION PLATE :- See HERE
This is the method I am going to use, uncommonly used when using 2.5 rods and pistons.
If I was you mate, I'd just go the normal 320 rods route, you will have to machine the pistons but hopefully you can! And maybe if you feel up to it, the M20 can be bored from 84mm to 86mm giving an extra 100cc, so you could make a 2.8. Alternativly if you could get an M50 crank you could make a 3ltr!!
Dan318-is
Post Thu Aug 18, 2005 11:21 pm
how hard is that
Jimbob
Post Thu Aug 18, 2005 11:25 pm
Decking the block is like having it skimmed several times.
Tbh I'm yet to find someone who's done this for under Ԛ£1k. Depending how/IF you do it, the pistons need shaving as well to sit on the crank right. If either of these steps are out by like 0.01mm you'll pink. The measurements the machine shop gave me were down to 3 decimal points! (Hmm, priceless figures in fact!)
Widge
Post Thu Aug 18, 2005 11:26 pm
Well, you'd need to machine the front of the crank to accept the timing belt pulley, but that could be simple if you have a big enough lathe as it's only a straight shoulder with a woodruff key. You may have to modify the clutch end too. Then you would have the interesting job of finding suitable sized rods!! Adam will know he's got one. Do you realise it will be Ԛ£350+ in parts alone to recondition the engine?
Dan318-is
Post Thu Aug 18, 2005 11:27 pm
f*ck this its all come at once
il do some research an think about it in bed lol
sounds expensive i mite just do up the m20
any other project ideas then?
bigdek
Post Thu Aug 18, 2005 11:28 pm
so is most of the money spent on machining ?
Sjoerd320i
318-is wrote:f*ck this its all come at once
FI :lol:
Widge
Post Thu Aug 18, 2005 11:29 pm
Jimbob wrote: If either of these steps are out by like 0.01mm you'll pink. The measurements the machine shop gave me were down to 3 decimal points! (Hmm, priceless figures in fact!)
That's why I'm completely removing the machining process, and going the decompression plate route - cheaper than machining, just bolts togeather, and only one measurement to get right.
bigdek
Post Thu Aug 18, 2005 11:33 pm
where do u buy such a plate ?
Jimbob
Post Thu Aug 18, 2005 11:37 pm
bigdek wrote:so is most of the money spent on machining ?
Not just machining, my receipts folder quadrupled in about 3 months spanning over Ԛ£2k..
Just over a tenner per 1bhp :P
Karan
Post Thu Aug 18, 2005 11:44 pm
2.7 rules thoughԚ¬!!!
i love mine and have become really attached to the way the power delivery is!
Karan
Moofles
Post Fri Aug 19, 2005 12:57 am
wait till the gt-r karan... :D
tbh i heard if you want a 2.7, whichever way you go you're looking at 1k+
'08 GSX-R750, '02 CBR600F, and a beast of a Focus 1.8LX...
My old sig :( - http://img52.imageshack.us/img52/2652/funnyface8eg.gif
Widge
Post Fri Aug 19, 2005 9:10 am
bigdek wrote:where do u buy such a plate ?
HERE
Post Fri Aug 19, 2005 9:16 am
Moofles ,ain't you got a chariot yet? you NEED my TrulyRancid7 ragtop then you would be able to savour on the edge open top motoring again. I'll do you a good deal. :)
Stevin
Post Fri Aug 19, 2005 11:35 am
Haha, I'm not even gonna say anything.
Cause I would be repeating myself, but I think this is the best bottom end for a stroker.
http://www.e30zone.co.uk/modules.php?na ... highlight=
The route I'm going, this is after quite a bit of research
Widge
Post Fri Aug 19, 2005 11:54 am
Did you use the M3 piston rings in the end then?
Stevin
Post Fri Aug 19, 2005 12:08 pm
Yes I did... though it was safer, even though it is more expensive.. rather not modify something u don't have to
Widge
Post Fri Aug 19, 2005 12:15 pm
Yeah, thought it was a bit silly modifying unnessicrily to avoid th cost of rings, the M3 must be up to the job. How much machining did the crank take? And what cc is the engine now?
