735i conversion
Artis
just bought a 735i so i can put the engine in a e30 the only thing is its auto i want it to be manaul wot gear box can i use to do this
Toby_Unna
- Boost Junkie
what 735i, an e32?
u need a manual box from an e34 530i or 535i or an e32 730i or 735i. and ideally a manual flywheel and clutch from an e28 535i/m535i.
Artis
cool that shouldnt be to hard to find will all the prop and diff be ok to use
Jos
Diff might be ok to start with, depends if it is a small case or a large case diff, what car is the e30? Also with the larger engine you will probably need to drop the final drive ratio a bit, probably 4.1 or 3.91 at the moment, really for the 3.5 you need a 3.64 or a 3.25 (or a 3.45 if you can find one).
The prop might be ok, but will probably need shortened to make up for the extra length of the engine/box.
You can't use the diff from the 735 as the output flanges on the halfshafts are different, it's a real kicker as all the 735s came with 3.25:1 slippers...
'94 e36 tree climber
