5.0 v8 twin turbo e30
Returnof318i
has anyone seen it yet i saw it at brnads hatch from prism motorsport utterly amazing do you wanna see pictures
dazleeds
- old skool raver
yesyesyesyes pics please Daz
www.oldskoolfantasy.co.uk
Daryll
My god yes please....don't suppose there are any vids as well???
@e30_daryll
e30_Turbo
- Boost Junkie
I've seen this, it's awesome, something around 720bhp!!
It's certainly had some money spent on it, it was in last months PBMW too.
I'm sure that prism motorsports website has the pics
http://www.prismmotorsport.co.uk/
but the site is under construction
slideordie
Sounds amazing. I have a video of a swedish 2.5 turbo @600hp and its the best sounding car i have ever heard. Anyone know where you can host video files?
glenn
- Engine Transplant Services
i read about that in one of the mag's a long time ago.
it has a 5.0 tvr lump in it
e30_Turbo
- Boost Junkie
e30_Turbo
- Boost Junkie
I wonder how much Ԛ£Ã”šÃ‚£Ãƒ”šÃ‚£Ãƒ”šÃ‚£ has been spent on that thing
PRISM MOTORSPORT BMW E30 V8 TWIN TURBO
Normal Race Conditions Power Output @ 8 PSI
548 bhp
580 lb/ft @ 6200rpm
Qualifying Power Output @ 23 PSI
670 bhp
700 lb/ft @ 7200rpm
Engine
All alloy TVR based unit 5.0 L twin turbo injection
4 bolt main
96.3mm top hat liners
Forged and coated WRC pistons
H-section steel rods
Steel billet knife edge and tuff-ride crank cross drilled
Special profile cam with dual adjustable timing gear
ARP bolts throughout long stud conversion
Group A trap door sump and crank scraper with external oil pick up
Heads special cast alloy heads with twin external oil returns
Super large inlet and exhaust valves
Pro comp roller valve gear
Hardened push rods
1.3mm cooper head gaskets
Induction System
Twin roller bearing turbo units T28/T40B water-cooled special built units
Front mounted air to air intercooler
Twin Alloy air boxes with integrated 52mm ram air trumpets
740cc injectors on 48mm throttle bodies twin swan neck manifolds
Management system by SDS self program
Exhaust
Custom built 4 branch headers 1 3/4 inch stainless steel from turbo outlet twin 3inch down pipes into 3 1/2inch bore system with single back box
Running Gear
Dodge Viper 6 speed box
One piece 3" prop.
Modified M3 axle with 5" UJ sliding shafts
Suspension
Front - Leda 2 1/2" coil over units with two way damping 745 lb springs
Rear - Leda 2 1/4" coil over units with two way damping 425 lb springs
Both front and rear adjustable anti-roll bars
Top camber adjusters
Brakes
Front - 382 mm Discs with Twin 6 pot callipers on each wheel
Rear - 315mm Discs Single 4 pots
Adjustment via rear brake compensator control & front to rear brake bias
Wheels
9 x 18 Dymags Front with Hoosier 245/40/18 race radial tyres
10 x 18 Dymags Rear with Hoosier 275/40/18 race radial tyres
Interior
Full Race Spec internals
Stainless Steel Roll Cage
Safety Equipment to FIA specification
Car built as a special saloon
sounds like Ԛ£50-Ԛ£80K if you ask me
Jimbob
Talk about old news
320Touring
dude, you alright today?seem a bit sarky from the jimbob we usually see?Jimbob wrote:Talk about old news
hope you're ok
Turbo-Brown
- Boost Junkie
Hmmm, wonder if that's a Rover V8, or TVR's own funny Vee angle effort.
320Touring
the clues are there if you look hard enoughTurbo-Brown wrote:Hmmm, wonder if that's a Rover V8, or TVR's own funny Vee angle effort.
Turbo-Brown
- Boost Junkie
Yes did see that, but TVR used both engines, and both came with 5litre capacities so it could be either.
Paul325i
That's been about for years, cool bit of kit though.
Way to complex though, silly turbos when they should have charged it.
320Touring
just messing dudeTurbo-Brown wrote:Yes did see that, but TVR used both engines, and both came with 5litre capacities so it could be either.
glenn
it's of the rover variety
Sjoerd320i
that rollcage looks cool
yes the car too but never noticed the cool rollcage
Zayyan
It looks ridiculous with all those stick-on bits, but nobody would agree with me before
320Touring
bollocks-its got the power to back up the looksZayyan wrote:It looks ridiculous with all those stick-on bits, but nobody would agree with me before
Zayyan
I suppose......ridiculous looks, ridiculous power
Dee
Clive anderson is the owner of PRISM MOTORSPORT and is based in ENFIELD north London. Turns out some top work and done by his own hands
SIT BACK HOLD TIGHT & SHUT UP
Darryl
Adammcf
That engine is fantastic!
Hyperion
looks amazing, is it a project/show car or are they gonna racer it somewhere!!!
Kos
seen the car been in the car, it is AWSOME. the brakes are to die for, twin 6pots per front wheel, its all his own work, so is the cage, 720bhp at only 16psi of boost!!!
clive is the guy helping me with my M335i turbo, did some of the fabrication work.
no one can say a bad word about his work or his car, if they have the balls too they sould be shot!!
Kos
he races in the V8 rolling thunder race series, mental and scary stuff and its edge to edge bumper to bumper stuff, makes touring cars look boring( well they have been fot the last 7 years)
Project_E30
I see you found the thread then KOS.Kos wrote:he races in the V8 rolling thunder race series, mental and scary stuff and its edge to edge bumper to bumper stuff, makes touring cars look boring( well they have been fot the last 7 years)
Kos
i have indeed, his car is mental !!
every time i'm at his work shop i spend about an hor looking and drooling at it, and i've been told what it would cost for me to buy and have it as a toy to play with, it could almost be steet leal again!!!
imagin that on southend seafront on a saturday night or what the purist swould say at donny and gaydon!!
sgc1001
put quite simply, that is a mean bit of kit and the ultimate boys toy!
d6dph
oh.......just made a nasty mess in my undercrackers. thats mega!
