i removed the eyebrow's and replaced the blue led side lights with
originals and that was it.
passed and no advisories."get in there"
finger nail munch time +5 smokes.
eyebrowless
just need to put them back on in a mo
Mick. You're a sick puppymagpie wrote:replaced the blue led side lights with
originals
That looks so much better without the browsmagpie wrote:
OT I know and I apologise....magpie wrote:
Mick, you are a poet, Sirmagpie wrote:i may be a sick puppy but my tail is wagging
LOL I had excessive corrosion and excessive movement last week - second time lucky, MOT green certificate in my hand today so make that another pass to add to the thread!Rich_W wrote:Any car the fails the MOT is probably seriously dangerous. It's so very difficult to actual fail. Play in a bearing is not sufficient. Has to be EXCESSIVE
http://www.motinfo.gov.uk/htdocs/m3i00000101.htm If you're interested
Slight pitting on the outer edge( the 335mm disks will cure thatgareth wrote:advisory on corroded discs perchance?![]()
methinks you don't use them enough
