help needed!!!
fozzy325is
Post Thu Aug 11, 2005 6:36 pm
any one know what an m535i is worth with full leathers? and what 2 watch out 4 when buying one is the m30 engine reliable?
TOURINGDADDY
Post Thu Aug 11, 2005 6:37 pm
just the same old probs as the e30 heads mate THEY CRACK
Post Thu Aug 11, 2005 6:40 pm
they rust from the inside out!
M30 engines are bombproof man can do 300k easy, usually the gaskets on the heads so i'm told
near mint ones go for only 2k
zaust
Zone day release
Post Thu Aug 11, 2005 9:26 pm
look in exactly the same places as e30 but also check where the fire wall
meets the bulk head as they tend to crack there and once that has happened forget it. also check the pan above the rear dif they tend to rot
around there.
M30 Tech 1 Touring on gas.
