hi people. how easy is it to take an engine out? ive got a 325i that needs the engine,gearbox and
propshafts etc. out. i can get an engine crane for it
and also is the loom the big band of wires thats goes
behind the dash? cheers for any help
engine transplant
Martinaston
Hi
I would not say it's easy but then again there is no one thing that will cause a major problem.
The best way i found is to drop the whole lot out the bottom but that meeans raising the car quite high.
If you take it out the top with the hoist (bonnet off, rad out) you will need some help to tilt it to get the gearbox clear (if you leave it connected) and don't forget the reverse light switch and clutch slave cylinder, It's best just to unbolt it from the gearbox to save you the trouble of bleeding it upon refit.
The loom will need to be unpluged from the ecu and fed back through the bulkhead and unclipped from the rear of the engine bay. One terminal from the battery and one for the engine earth to the bodywork (normally on the bottom) unscrew the c101 plug from the socket next to the fuse box and thats about it (i think
There is NO nucleus.
A1BMW325iSport
if the shell is being scrapped cut out the top panel, then you hardly have to lift it, it will come out straight forward, much easier i find
Martinaston
Good idea.
I wish someone would make a conversion kit to change the front panel to a removable one like the 46.
A1BMW325iSport
i know mate, the e34 front end comes off as well
eun
thanks everyone by the way how easy will leather from a
4 door go in my black coupe
Adam318i
It should do but then the front seats wont tilt forward
Bit of a problem.
Adam
Bit of a problem.
Adam
I love my Rice!
