can any body use this
ian332isport
- Contact:
What size fisch does it take ?gaszman wrote:iu have a micro fisch machine fully working need it out of the way before it goes to the tip . any body
Si had all the micro fisch slides for the e30.gaszman wrote:iu have a micro fisch machine fully working need it out of the way before it goes to the tip . any body
EThreezero
Ah but do you have the micro fisch tank to put them in?
*******MERC E240 BREAKING..1998...LEATHER...ALL PARTS*******
- secondtimelucky
EThreezero wrote:Ah but do you have the micro fisch tank to put them in?
Wanted: Any old component speakers, complete or separate parts, let me know what you got
SteSE
- Heading for the Naughty Room
- Contact:
I will find a good use for it, what make is it. Is it just a reader or reader printer. Where is it located?gaszman wrote:iu have a micro fisch machine fully working need it out of the way before it goes to the tip . any body
Trevor, i've converted all those fiche already pop round for a cd. Powelly i'm sorry dude i've not whizzed them over to you yet.
Steve the mod, any answer on hosting the workshop manuals on the zone or wiki???? Or any other mod wanna answer???
aranib wrote: "wat is it"
This:
http://www.wisegeek.com/what-is-microfiche.htm
The sort of thing you'll see the parts counter guy using to look up technical drawings, etc.
This:
SteSE
- Contact:
Microfiche was basically an old method of storing data. On a normal fiche you could store up to 60'ish sheets of a4 paper on a fiche the size of a post card. A special machine called a reader is needed to view the documents. A reader printer can then print out the documents at its original size.
The motor industry sometimes used Jumbo fiche where hundreds of pages could be stored on a single fiche (albeit larger than a post card). Specials equipment is needed to view/print from these.
Many people believe that microfilm is still the best method or storing data over electronic format. Time will tell.
And that concludes are microfilm lesson for today.
