easy power gains for 325i?
glenbat
Post Wed Aug 03, 2005 9:52 pm
are there any? Got a 325i but wondered what the next step is? are there any quick and easy power gains?
cheers
glen
Davenotouring
Post Wed Aug 03, 2005 9:54 pm
PM Ant about a zone chip to start with.
Then think about a Big Bore Throttle Body.
Should liven it up a bit.
BMW 328i Cab - Daily Slag
Post Wed Aug 03, 2005 10:15 pm
Chip
BBTB
6 branch
All the basic bolt on stuff
after that its cam, Emerald/MAF, headwork
glenbat
Post Fri Aug 05, 2005 9:42 am
BBTB? :oops:
Davenotouring
Post Fri Aug 05, 2005 9:58 am
Big Bore Throttle Body :)
glenbat
Post Fri Aug 05, 2005 10:12 am
cheers dave, im new to bmw's (incase you hadnt guessed!!)
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Fri Aug 05, 2005 10:41 am
I don't have a 325 but *everybody* here says the two first power mods are bbtb and zone chip.
I think you need:
chips"AT"e30zone.co.uk - ant 55squid for the chip and you can easily fit it yourself.
alpina527"AT"aol.com - BBTB ~130 iirc, proably easily fit that too.
And a LSD if you haven't already got one. not only will the car be more controllable in a slide but the ratio change from 3.64 (stock open diff) to 3.91 (sport LSD) will give you acceleration gains too, albeit at the cost of higher revs for m-way cruising... not sure what the RPM vs. Speed differences are but I'm sure somebody here can tell you. Cue Karan.
M5pilot
Post Fri Aug 05, 2005 11:01 am
Chip, Big Bore Throttle Body and BTB 6 branch are the best and easiest ways to gain some performnance and very much increase driveability.
Chip = Ԛ£55
BBTB = Ԛ£120
BTB 6 branch = Ԛ£450
I would definately recommend a good induction kit like the Pipercross and get a good exhaust system on. For around Ԛ£800-Ԛ£1000 you can totally transform your car.
Hyperion
Post Fri Aug 05, 2005 12:08 pm
Hi guys, here is something strange but i am from South Africa and i phoned a tuning company called Steves Auto Clinic (SAC) to find out how much to chip my 1991 325i. The guy told me that it cant be done :( because my car has a Airflow Meter. They can only Dyno tune the car for me?!?!?
Any Ideas?
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Fri Aug 05, 2005 12:11 pm
Hyperion wrote:Hi guys, here is something strange but i am from South Africa and i phoned a tuning company called Steves Auto Clinic (SAC) to find out how much to chip my 1991 325i. The guy told me that it cant be done :( because my car has a Airflow Meter. They can only Dyno tune the car for me?!?!?
Any Ideas?
Obviously not true.
Post Fri Aug 05, 2005 12:14 pm
Any Ideas?
tis bullshit
Hyperion
Post Fri Aug 05, 2005 4:17 pm
thought as much, the f*&king fool
