Z3 short shift
cliffybabe
- Powered by Nelly
cliffybabe
- Powered by Nelly
snapgooner1 wrote:http://www.e30zone.net/e30zonewiki/inde ... conversion
- **BANNED**
Replace ALL moving parts and washers and clips.Do not try to save a few pence by re-using the original parts.
When complete,the Z3 short shift is a pleasure to use,even my wife says so!
Youth is wasted on the young.
So basically thats all the parts listed in the wiki minus the exhaust gasket listed at the bottom!daimlerman wrote:Replace ALL moving parts and washers and clips.Do not try to save a few pence by re-using the original parts.
I think it costs closer to £70 to get all the parts, but apparently it makes all the difference.MarkF wrote:So basically thats all the parts listed in the wiki minus the exhaust gasket listed at the bottom!daimlerman wrote:Replace ALL moving parts and washers and clips.Do not try to save a few pence by re-using the original parts.
Uni is killing the project.
- andyclient
Did mine a while back excellent mod imo
cheers
Andy
cheers
Andy
__________________
88 E30 M3
51 E46 320 Se Touring
93 E36 325 TD Gone but still going !
83 E30 320i (alas long gone)
87 E30 Hartge 325i (gone but not forgott
88 E30 M3
- andyclient
its just like a short shift kit . the length and throw of the gear lever is reduced making it feel more positive imo
cheers
Andy
cheers
Andy
__________________
88 E30 M3
88 E30 M3
cliffybabe
- Powered by Nelly
Mine cost 20quid i bought the shifter 2nd hand off eko (tony)
Its a easy job to fit didnt change any of the bushs either as mine had recently been replaced just releaseing the white one around the gear stick was a git but i done it
Must admit though upon first fitment i put the shift round the wrong way
, but thats how it was fitted on the old shifter so it must of been wrong when i got the car. "min job though took the clip off and spun it job done
It made the car feel a different beast notchy and more positive threw the gears
cliffybabe
- Powered by Nelly
yepBatesy8 wrote:So just the blue highlighted parts in the wiki article are required to make the box feel shorter and tighter?
Mine cost £76 for ALL the genuine parts including a new shift rod and exhaust gasket thingy (technical term). Refurbished every washer and clip all the way back and it makes a massive differenceNayC wrote:I think it costs closer to £70 to get all the parts, but apparently it makes all the difference.MarkF wrote:So basically thats all the parts listed in the wiki minus the exhaust gasket listed at the bottom!daimlerman wrote:Replace ALL moving parts and washers and clips.Do not try to save a few pence by re-using the original parts.
'90 325i Sport
Yes it does, the bush at the gearbox end of the shifter rod is a bit fiddly to get out and refit but worth it I think. Absolutely fine if you don't replace it (and cheaper), it's not essential...I'm just a bit particular about things like that!
'90 325i Sport
cliffybabe
- Powered by Nelly
u'd be able to feel it from what i remember reading, I didnt need ot adjust mine
rado-steve
Daft question but why do you need the zorst gasket??
Nugget Yellow Corrado 1.8T
Tornado Red Mk2 Golf GTI
But ur wife is using the short shifter for a different type of pleasuredaimlerman wrote:Replace ALL moving parts and washers and clips.Do not try to save a few pence by re-using the original parts.
- secondtimelucky
armanib wrote:But ur wife is using the short shifter for a different type of pleasuredaimlerman wrote:Replace ALL moving parts and washers and clips.Do not try to save a few pence by re-using the original parts.
Wanted: Any old component speakers, complete or separate parts, let me know what you got
Daimlers gone to smell his gearnob now loolsecondtimelucky wrote:armanib wrote:But ur wife is using the short shifter for a different type of pleasuredaimlerman wrote:Replace ALL moving parts and washers and clips.Do not try to save a few pence by re-using the original parts.
When complete,the Z3 short shift is a pleasure to use,even my wife says so!thats actually pretty funny
From what I've heard, you can access the gearbox linkage from under the car.yeah_mick wrote:to replace the bushing aswell, is that a gearbox off job? or can it all be done on the car? im guessing the exhaust gasket is because you need to take the exhaust and box off to do it?
Remove it, rebuild it and place it back in. Is it possible to do it that way? (Mine was done when I bought the car, but I'm going to re-do it as I rebuild the car).
- Brianmoooore
Nothing has to be removed to change all the linkage, though it's certainly easier with the prop and exhaust off.
Remove the gearbox crossmember and lower the rear of the gearbox down a little makes things easier, but watch out for things getting stretched under the bonnet, and the fan getting intimate with the radiator.
The oil seal on the shaft coming out of the gearbox should be changed as well when the joint is off.
