Looking at borbet alloys. What size do you recommend.
Nay
Channel Island Crew
Channel Island Crew
Thu Jul 09, 2009 6:31 pm
I've always loved deep dish wheels. I want them for my E30 as E30s suit deep dish alloys and I doubt i'll have another car that can pull them off (and be young enough/daft enough to fork out for them!)
Its E28 for the offset in E30s isn't it? Need to be clear on that!
What I want to know is about widths though!
I know 7"/7.5" is a common wheel size but they are often too skinny. What are 8" like? 9"?
For 9j 16" wheels, do you need to roll the arches? What does it take for a bodyshop to do this? Front and back? Debating on 9 all round or 8 front 9 rear.
What do people think? I have the 15" BBS for originality, so dont throw stuff at me! :P
Uni is killing the project.
Cypriotgeeza
Thu Jul 09, 2009 8:24 pm
i agree with you 100% on the deep dish rim mate!
have always loved them...but couldnt wait to get my E30 to put some on...i still dont know which ones to go for lol :o:
which ones you thinkin of getting?
Check my M30 build threads:
leeparkes
Thu Jul 09, 2009 9:32 pm
For a 9j rim im sure the offset has to be ET15 and you will need to roll the arches
Dont think you can get 8j (could be wrong)
turbo87
Fri Jul 10, 2009 3:37 am
On mine i have 7.5 on the front and 9's on the rear but you can also get 9" all round depends on what you want.
harry_p
Fri Jul 10, 2009 10:44 am
the ideal offset will change with the wheel width. a wider wheel often means needing to use a lower offset to keep the inside edge away from the strut / inner arch, which means you're pushing a wider wheel further out in the arches.
there are plenty of people running 9s all round, but most will have seen a fair bit of arch work, run stretch tyres and stiff suspension.
very wide deep dish wheels also look terrible at standard rideheight, so if it's not already dropped, budget some 60/40 springs in with your wheels and tyres.
cheers,
harry
Nay
Channel Island Crew
Channel Island Crew
Fri Jul 10, 2009 10:55 am
8j is available on the borbets I've been looking at. 7,7.5,8,9.
I'm thinking of Borbet BS
Looking at that photo, is it only the rear arches you have to roll, and how do you do that?
Although, these alloys sit just behind borbet b's for me!
Can anyone reckomend and alloys similar to BBS cross-spokes or borbet bs's that have a dish? I personnally dont really like split rims, but some of you may be able to tempt me! Things like BBS RS?
Fri Jul 10, 2009 1:23 pm
You've seen the light :D
My arches aren't rolled but only got a 40mm drop so it helps. You want a lower offset with wider rims, mine are 15 IIRC.
I prefer the staggered set-up, 7.5J upfront and 9J at the rear :cool:
Borbet A's look very nice, just look at Oakey's Tech 1 :drool:
Nay
Channel Island Crew
Channel Island Crew
Fri Jul 10, 2009 1:29 pm
I want "poke out the rear" wheels, yours are nice, but they sit too tamely at the back. need the wheels pokin' out.
9" all round mate :drool: Mine will be a 30-40mm drop. may even do a 40/30 drop. :D 60/40 is too rude for me :P
Need to look into rolling the arches. Thankfully, plan on getting the whole body done eventually. So will look at it then.
Do you need to roll the front arches too? (for 9j's?)
Fri Jul 10, 2009 3:39 pm
To pull it off properly, you need it as low as possible, 'gangsta low' innit winkeye
The front should be okay but for the price, it's probably worth doing anyway :)
turbo87
Fri Jul 10, 2009 5:45 pm
Iv got mine on coilovers no need to roll the arches and its slammed. check out the pictures of it in the photo section of the forum :)
Nay
Channel Island Crew
Channel Island Crew
Fri Jul 10, 2009 6:03 pm
What difference do coilovers make? Thought they where just a type of suspension for track use.
cliffybabe
Powered by Nelly
Powered by Nelly
Fri Jul 10, 2009 6:08 pm
its all about the dish :cool:
Nay
Channel Island Crew
Channel Island Crew
Fri Jul 10, 2009 6:13 pm
Neil, I've told you before (a while back, tho) to stop showing off your borbets unless you'll sell me a set!!! p.s. do you still have a set? :rofl:
turbo87
Fri Jul 10, 2009 6:49 pm
Depends on what your going to use the car for. I had the car on springs and i could not have people in the back as the wheels would rub the arches but now that iv got it on coilovers its ok and i have it much lower then before. The only reason iv gone for coilovers is i plan on using the car on the track and changing wheels etc.
cliffybabe
Powered by Nelly
Powered by Nelly
Fri Jul 10, 2009 6:58 pm
NayC wrote:Neil, I've told you before (a while back, tho) to stop showing off your borbets unless you'll sell me a set!!! p.s. do you still have a set? :rofl:
:lol: na there not going anywhere
as for 9's all round with the stretched tyres and a 40mm drop all round ive had no issues, im also using the uprated top mounts off a e46 m3 cabby
not even people being in the back but im running 205/40/16 profile rubber
Sat Jul 11, 2009 11:09 pm
Check out German eBay Nay, there is a set exactly the same as mine on there for £250 winkeye
steerfromtherear
Sun Jul 12, 2009 10:44 am
Get the wheels you posted in 8j front and 9j rear and they would sit nice.
I found when rolling on 9j borbets all round you get reverse poke (which sounds painful). Front wheel sticks out more than the rear wheel.
This might be down to the camber on the rear making it appear that way but either way it looks shonky imo.
If I did it again Id either run a staggered set up, fit spacers to the rear to give it a bit more poke or fit some camber adjustable front top mounts and wind on -3 degrees.
e30bmlover
Ac Schnitzer prophet
Sun Jul 12, 2009 10:55 am
cliffybabe wrote:its all about the dish :cool:
i like cliffy!!!! they suit the e30 very well!
m_jermyn
Sun Jul 12, 2009 11:30 am
Im getting some of these just like the BBS RS have a looksy..
http://losangeles.craigslist.org/sfv/pt ... 27954.html
available here or at their site..
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 725wt_2054
They come in a few different colours aswell
Mike
m_jermyn
Sun Jul 12, 2009 11:39 am
m_jermyn
Sun Jul 12, 2009 11:40 am
m_jermyn
Sun Jul 12, 2009 11:47 am
Or something a little different
Nay
Channel Island Crew
Channel Island Crew
Sun Jul 12, 2009 7:27 pm
m_jermyn wrote:Image
I want them :drool:
Eddie25
Sun Jul 12, 2009 7:40 pm
Here's mine on Ronal LS. I love them...
