Scuttle Panel
minicooper172
Sun Jun 14, 2009 7:40 pm
Does anyone know if you can get replacement scuttle panels?
Took a stab at the scuttle panel the other day and found this!
This is what filled the gap:
And this is what I've done to get the rust out...
Now, this hole is a right pain in the arse due to the complex curves, and the brazed panels mean you can't weld to all of the egdes.
A new scuttle would make this a whole lot easier!
bdx
Sun Jun 14, 2009 8:20 pm
Cut it out of another car
ROC
Sun Jun 14, 2009 8:23 pm
You can still buy one from BMW.
cypriot_boy_2k7
Sun Jun 14, 2009 9:05 pm
bmw do it and stamp ur numbers on, give them a ring ding
e30325iauto
Sun Jun 14, 2009 10:34 pm
Noticed your in Brighton,
There is a mint e30 at Bridges scrap yard (crawley area) you could butcher.
minicooper172
Sun Jun 14, 2009 10:48 pm
Good point, I'll check that out... How long has it been there for? Not sure how long their cars last?
Thanks for the replies by the way, I'll give the muppets at BMW a try. Last time they didn't know what an E30 was until I showed them the one I had sitting outside...
skipunda
Sun Jun 14, 2009 11:06 pm
:eek: well cut out and prepared though
Chris
e30325iauto
Sun Jun 14, 2009 11:19 pm
minicooper172 wrote:Good point, I'll check that out... How long has it been there for? Not sure how long their cars last?
2 weeks its a touring in the yard to the left. green in colour. I've just cut the same section out of a 2door in the bottom yard. Took 45 mins hacksaw and chissel/hammer only tools required.
Sanchez
Sun Jun 14, 2009 11:22 pm
e30325iauto wrote: 2 weeks its a touring in the yard to the left. green in colour. I've just cut the same section out of a 2door in the bottom yard. Took 45 mins hacksaw and chissel/hammer only tools required.
Is it dark green(malahite). Do you now if the tailgate is nice?
M3BOB
Sun Jun 14, 2009 11:29 pm
bmw do one with your chassis number stamped in it, dont think you can buy them blank anymore
minicooper172
Sun Jun 14, 2009 11:46 pm
Half a scuttle will do the job, I only want the bit that's missing...
Have to wait tomorrow until I can find out how much one is going to cost.
euan
Mon Jun 15, 2009 11:25 pm
mine cost about £40 from stealer in edinburgh, took around 10 days to get stamped etc
Barx325i
Mon Jun 15, 2009 11:45 pm
that's a fair mess..
Bob_S
Tue Jun 16, 2009 12:04 am
£31 for the last scuttle I saw leave BMW
Bollocks to this 24v scrap!
Tue Jun 16, 2009 12:35 am
The stuff in your hand, in your second pic, is a lump of hardened sealant, and is what caused the problem.
It's applied at the factory to seal the scuttle box from the screen pillars, etc., onto unpainted metal. After 15 - 20 years the sealant hardens and shrinks, pulling away and leaving a very small gap from the underside of the scuttle. Water is drawn into this gap by capillary action, and the metal soon rusts through.
On the plus side, the rust is unlikely to extend more than a few millimetres from the hole, and can usualy be repaired by a carefully shaped and welded plate, although yours seems to have had an unusually large blob of sealant.
Bob_S
Tue Jun 16, 2009 12:37 am
Brianmoooore wrote:The stuff in your hand, in your second pic, is a lump of hardened sealant, and is what caused the problem.
What the OP appears to be holsing is an averagely sized (for an e30) lump of p40, with some aluminium mesh to aid the shaping of said p40
Tue Jun 16, 2009 12:40 am
Bob_S wrote:What the OP appears to be holsing is an averagely sized (for an e30) lump of p40, with some aluminium mesh to aid the shaping of said p40
On closer inspection of the pic; you're right!
If it was the first time the hole appeared though, it would have been sealant!
Bob_S
Tue Jun 16, 2009 8:57 pm
Your right though. It would have been sealant.
