5 Stud Hub Conversion
G-DaTourer
Fri Jun 12, 2009 2:37 am
I would like to convert to 5 stud hubs, is this simple to do without going for M3 parts. Been told E36 hubs fit but not sure info is correct.
harry_p
Fri Jun 12, 2009 2:59 am
try doing a search, it's been covered a lot of times!
you can use e36 bits, but you'll need the complete hubcarrier, hub / bearing , strut, disks, callipers etc at the front as well as offset bushes and topmounts to try and get the geometry to somewhere near where it should be, and will probably mean needing to use high offset e36 wheels. at the rear you can use 318ti compact complete rear arms.
cheers,
harry
Fri Jun 12, 2009 10:59 am
Why do you want to swap to 5 lug then?
G-DaTourer
Sat Jun 13, 2009 11:20 am
I'v got a set of 5 stud 18" and 19" alloys, also looking at fitting M3 style wide bodykit. Thought if it was an easy thing to do i could use wheels i got, might look and see what big and wide 4 stud wheels are available.
Graham
If you can still hear, your audio aint loud enough!!! WHAT
325i Tourer Auto
325i Tourer Manual
325i Sport 2 door (Doner car for Project BM)
316 Lux 2
Sat Jun 13, 2009 3:32 pm
Not cheap to do it properly
da4x4turbo
Sat Jun 13, 2009 4:02 pm
harry_p wrote:try doing a search, it's been covered a lot of times!
For some reason any time anyone asks this particular question most people say to do a search. I've never actually seen one of these threads pan out.
But I can't find anything on the topic easily using the search function. Maybe it's just "finger trouble" on my part, but either way it'd be nice to have the info posted in a thread every now and then so as when using the search function you don't just find 4,000,000 threads with this subject heading in which there's two or three responses saying to use the sodding search function!!! :D
Anyone who knows of an S50 B32/B30 E30 for sale, please let me know.
12345kevin
Sat Jun 13, 2009 10:22 pm
http://www.e30zone.net/modules.php?name ... light=stud
Read Jaistanley's post, give you all the right bits to get close.
MarkT
Sun Jun 14, 2009 10:05 am
Yeah, i found that one too when I was asking the other day. Forum search facilities are poor, but then again, the same on all forums!
nickso
Sun Jun 14, 2009 1:15 pm
the search facility is good if you know how to use it.
you have to think a little before you put your search terms in. putting "5" and "stud" in is going to get you every thread with the number 5 in it and everything with stud too.....i just checked and its 1300 threads. putting "stud and conversion" in will get you are far more manageable 250 threads and the first page had at least 15 titles with 5 stud conversion or similar in them.
i find always using "and" in between you terms helps.
having said all that i still cant find some stuff im looking for. :D
'88 e30 328i M52 track bint.
Benho
Sun Jun 14, 2009 1:46 pm
18"/19" will make the ride in an e30 horrid!
MarkT
Sun Jun 14, 2009 1:47 pm
nickso wrote:the search facility is good if you know how to use it.
Learn something new every day!
nickso
Sun Jun 14, 2009 1:59 pm
every day is a school day. :D
