electric windows and central locking
chrisE318is
Fri May 29, 2009 8:41 pm
ive got a problem with my windows.... when either doors are open the windows go up and down fine but when the doors are closed they dont work? anyone no why? also i have no central locking, it doesnt work in any key hole as if there was never had any. but my print out says it should have.
breaking 2 door dolphin grey tec 2
pm me
toby
Fri May 29, 2009 8:49 pm
think with doors open and doors closed uses a different fuse
check fuses?
Fri May 29, 2009 8:59 pm
This should be in the tech section, but anyway.
You should have a central locking relay mounted behind the driverside front footwell speaker.
Take the speaker out and the realy is mounted inside the footwell, held by 2 screws.
Undo these and take it out.See if you can hear it working when trying to lock the doors.
If no joy, the check the door pins under the rubber cover in the door a pillar, ir the wires are corroded, then u can do a simple mod.
Go in the see this.
http://www.e30zone.net/modules.php?name ... ed&start=0
If it the relay i have one working here.Let me know.The window probelem could be a number of things.
Check the black and green wire from pin 15 on the E30 C101 plug.
HTH
chrisE318is
Sat May 30, 2009 1:58 pm
sorry for putting it in the wrong section. im probably being really thick but dont no what the e30c101 plug is :o: can you tell me where it is and what it looks like
pm me
Sat May 30, 2009 2:04 pm
C101 plug is located bt the bulkhead and looks like a round plug
SPADGE
Before you do any of the above check that the small wire on the smallest terminal of the starter motor is making a good connection!
Sat May 30, 2009 2:11 pm
I was going to say that Spadge, but thought i might be barking up the wrong tree, so didn't
SPADGE
Sat May 30, 2009 2:20 pm
Rav335uk wrote:I was going to say that Spadge, but thought i might be barking up the wrong tree, so didn't
It won't be the cause of the c/l problem but may be for the windows.
Worth a quick check anyway.
chrisE318is
Sat May 30, 2009 4:26 pm
right as for the windows there was a blown fuse so replaced that and it worked.... i wound down the window it went down half way and blew so im guessing theres something shorting out, in the door plug maybe?
pm me
Sat May 30, 2009 6:27 pm
Matbe, but with electrics, its difficult to narrow it down.
It will be shorting somewhere.
Was the fuse the correct rating???
toby
Mon Jun 01, 2009 9:31 am
Ah, I reckon as the window goes down it messes with your central locking wiring.
I had one where when the window went down it would lock all the doors as it puled on central locking wiring.
Take the door panel off and see if things are dangling about.
