Anyone with a non sport M20 gearbox out the car
E30Adam
Post Fri Jul 22, 2005 6:40 pm
Please could you have a look and see what numbers are printed on the bellhousing and also under the output shaft.
Richy325iTouring
Post Fri Jul 22, 2005 6:57 pm
Just replied to you pm fella
JazzMan
Post Fri Jul 22, 2005 7:40 pm
The side on mine says:
260.0.1346.90
and under the output shaft:
260.0.1060.91
from a 325i Touring
E30Adam
Post Sat Jul 23, 2005 11:15 am
Cheers lads.
This is strange, it seems that sport and non sport gearboxes are identical from the exterior.
In this case, how on earth do you tell a sport gearbox from a standard one?
Karan
Post Sat Jul 23, 2005 11:23 am
E30Adam wrote:Cheers lads.
what u can do is put it in gear.... turn input shaft like 10 times and see how many times the output turns round and calcuilate the ratios from there......
its the only sure way!
Karan
320Touring
Post Sat Jul 23, 2005 11:25 am
Karan
good thinking karan! really should be tagged like the diffs!! no S on the box???
cabrio327i
Post Sat Jul 23, 2005 1:55 pm
Hi Adam, These are the etk pictures i got from the dealers when i was checking my gearbox, and the location of the number is on the side of the casing, hope this helps mate, cheers Dave http://reg.imageshack.us/v_images.php?page=1<a href="http://img239.imageshack.us/my.php?imag ... 0056ey.jpg" target="_blank"><img src="http://img239.imageshack.us/img239/9912 ... 6ey.th.jpg" border="0" /></a><a href="http://img301.imageshack.us/my.php?imag ... 0046ma.jpg" target="_blank"><img src="http://img301.imageshack.us/img301/1308 ... 6ma.th.jpg" border="0" /></a><a href="http://img295.imageshack.us/my.php?imag ... 0035xo.jpg" target="_blank"><img src="http://img295.imageshack.us/img295/5753 ... 5xo.th.jpg" border="0" /></a>
Richy325iTouring
Post Sat Jul 23, 2005 4:54 pm
ok its just a thought but is it possiblethat the touring has the same box as the sport
min came from a touring and so did the one quoted in this thread
i could also be totaly off track her as well
E30Adam
Post Sun Jul 24, 2005 10:26 am
Quite a few tourings did have sport boxes in them so you could be right.
Does anyone have the ratio's of a sport and non-sport box?
Demlotcrew
Post Sun Jul 24, 2005 10:36 am
Adam look for a number on the bell housing, this is the GB number and is the only real way of telling.
A
E30Adam
Post Sun Jul 24, 2005 2:00 pm
Demlotcrew wrote:Adam look for a number on the bell housing, this is the GB number and is the only real way of telling.
A
Cheers Andy, will have another look. Any ideas where this number might be and how I tell from the number what type of box it is?
cabrio327i
Post Sun Jul 24, 2005 2:46 pm
Adam look at the reply i sent with the photos it tells you all you want to know mate, Dave
cabrio327i
Post Sun Jul 24, 2005 2:49 pm
Forgot to ad, the identification code for sports boxes is early ones TNN and later ones HM, cheers Dave
E30Adam
Post Sun Jul 24, 2005 6:28 pm
Cheers Dave, the links don't seem to be working mate, could you have a look at them for me.
JazzMan
Post Mon Jul 25, 2005 12:23 pm
So does this make mine a sport box? Confused as well here :)
cabrio327i
Post Mon Jul 25, 2005 1:41 pm
Ok guys, To put it in a nutshell you might say, if your box number stamped on the clutch release cylinder side of the clutch housing right on the outer edge finishes with either TNN early box or HM later box its a sports one ok, cheers Dave
cabrio327i
