m_jermyn
Fri Apr 17, 2009 12:37 pm
Thinking of painting my cluster needles red...... However I am a little worried about the needles visibility at night time... So can you see a red needle when driving at night?
Mike
m4xos
Fri Apr 17, 2009 12:39 pm
i think the m3 ones glow, if you have a spare speedo cluster, try it on that first!
goldysingh
Fri Apr 17, 2009 12:47 pm
I've done this and it looks fine in the dark, don't glow but you can see them clearly enough.
I think I saw a website once who do replcement needles..Can't remember the name.
Spike121
Fri Apr 17, 2009 12:48 pm
Just done my cluster and have no problem seeing the needles at night, fitted chrome rings as well
It`s a state of mind.
aj_mckay
Fri Apr 17, 2009 12:50 pm
Don't think the M3 ones glow, at least not E30 M3! E36, probably yes.
Search for 'red AND needles' in the search function and look at the thread by cliffybabe
He did this and messed around with all sorts of different lighting options on a cluster of his.
no2lurch
Fri Apr 17, 2009 12:51 pm
Spike121 wrote:Just done my cluster and have no problem seeing the needles at night, fitted chrome rings as well
pic please...
Felix79
- All loved up !
Fri Apr 17, 2009 1:56 pm
My Alpina dials are a bright orange.
The M3 Cluster I have ( a USA spec) has the red needles and you can see them just find at night.
Felix79 aka Dan
E85 Z4M Roadster
Joe-318i
Fri Apr 17, 2009 2:09 pm
mine are red, have no problem with seeing them at night, but there on a white background, might change dials back to black
'83 320i chromie
'86 316 tech 1/M20B25 conversion
'91 318is touring
'87 chromie M10 rightness
Joe-318i
leeparkes
Fri Apr 17, 2009 2:23 pm
I have red needles and you can see them fine at night
m_jermyn
Fri Apr 17, 2009 3:06 pm
Well I guess im going to paint them red then, surprised not one bad comment....
Thanks guys
Mike
TheHeap
Fri Apr 17, 2009 3:38 pm
you should be alright as i bought white dials for a car i had and i painted my needles black with a permenent marker, worked perfectly
andyclient
Fri Apr 17, 2009 5:06 pm
E30 M3 needles don't glow , but no probs at night as mentioned
__________________
88 E30 M3
51 E46 320 Se Touring
93 E36 325 TD Gone but still going !
83 E30 320i (alas long gone)
87 E30 Hartge 325i (gone but not forgott
jamie323i
Fri Apr 17, 2009 9:33 pm
What sort of paint would you use?
Enamel,like in those little pots you get from a model shop?
StuBeeDoo
Fri Apr 17, 2009 9:37 pm
jamie323i wrote:What sort of paint would you use?
Permanent marker (chisel-tip one).
I've done 2 sets. The ones on my white dials I can see fine in the dark, but I haven't tried the black dials in the car yet.
gooner1
- Out humping Reindeer
Fri Apr 17, 2009 9:38 pm
What about nail varnish? Not like they are going to be rubbing against anything, is it?
m4xos
Fri Apr 17, 2009 9:45 pm
gooner1 wrote:What about nail varnish? Not like they are going to be rubbing against anything, is it?
that sonds like a good idea to me!!
- E30 Zone Meets/Events Team
Fri Apr 17, 2009 10:43 pm
I used my missus red nail polish and it was ok.
gooner1
Fri Apr 17, 2009 10:46 pm
Rav335uk wrote:I used my missus red nail polish and it was ok.
Yes, but what did you use on your,e needles Rav?
Fri Apr 17, 2009 10:55 pm
gooner1 wrote:Rav335uk wrote:I used my missus red nail polish and it was ok.
m_jermyn
Sat Apr 18, 2009 1:09 am
This is basically exactly what I will be doing
m4xos
Sat Apr 18, 2009 2:10 am
i must admit, that clockset does look sweet! nice work RAV!!
Sat Apr 18, 2009 12:17 pm
Cheers M4xos
Mayze
Sat Apr 18, 2009 9:28 pm
I have to admit I had always thought diy red needles would look a bit cheap but that looks the dogs.
Ps I think the reason that people use red marker is the weight of the paint can throw the readings out for your dials.
StuBeeDoo
Sat Apr 18, 2009 9:41 pm
Mayze wrote:Ps I think the reason that people use red marker is the weight of the paint can throw the readings out for your dials.
Don't know about anyone else, but I did it because it's what the Lockwood website suggested.
StuBeeDoo
Sun Apr 19, 2009 9:51 am
monkey wrote:StuBeeDoo do you have a pic of your gauges ?
This is the Lockwoods, I'll get a picture of the standard ones later.
StuBeeDoo
Sun Apr 19, 2009 12:24 pm
..... And here's the standard black dials with permanent-markered red needles.
monkey
Sun Apr 19, 2009 3:32 pm
StuBeeDoo you done a good job there the standard black dials look
StuBeeDoo
Sun Apr 19, 2009 4:32 pm
monkey wrote:StuBeeDoo you done a good job there the standard black dials look
Thank you.
I'll probably put them in in the next few months. I'm still not sure about the white ones.
monkey
Sun Apr 19, 2009 6:31 pm
StuBeeDoo wrote:monkey wrote:StuBeeDoo you done a good job there the standard black dials look
Thank you.
i didn't know wot to think of the white dials , but didn't want to say anything
StuBeeDoo
Sun Apr 19, 2009 6:41 pm
StuBeeDoo wrote:I'll probably put them in in the next few months.
As you see, they're on 176k. The car is on 173k at the moment.
m4xos
Sun Apr 19, 2009 10:05 pm
i can see it now... red needles in mine during the week
