which is the better engine???
wayneE30
Post Fri Jul 15, 2005 7:19 pm
which one m10 m20 m40 (if i have missed any please say so)
i have read that the m10 is better as it is more tuneable
Taylor325i
Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
Post Fri Jul 15, 2005 7:40 pm
M 20 any day of the week - That is of course my opinion (thank fcuk you changed the subject from rear lights) :thumb:
wayneE30
Post Fri Jul 15, 2005 7:45 pm
:lol: :lol: :lol:
jonbuoy
Post Fri Jul 15, 2005 7:50 pm
M42 318is, i am thinking hard about this engine swap from the M40
jamesroools
Post Fri Jul 15, 2005 7:59 pm
and theres the m60, 2.0 and 2.5
Image Image
Taylor325i
Post Fri Jul 15, 2005 8:02 pm
And there's the S14 - 320is & M3
jamesroools
Post Fri Jul 15, 2005 8:04 pm
and finally the m21 2.4 d and td
Image Image
rowemeister
Post Fri Jul 15, 2005 10:33 pm
If we stick to E30 engines I believe either the M20 or S14 engines are by far the best. Its all down to whether or not you want 4 or 6 cylinders (forgetting the lovely M3 body here)
Also the S14 engine is pretty well fettled where the M20 has (if cash available) a lot of potential for good HP. Look @ some of the 2.7 conversions Bexley's have done.
The problem is anyone with a M3 wont want to put a M20 engine in and to be honest I dont blame them. It wouldn't be an M3 if they did.
I'll stop banging on now!! :bla: :soap: :bla:
325i Sport with Hartge H27 lump
Turbo-Brown
Boost Junkie
Post Sat Jul 16, 2005 12:04 am
Depends what you mean by better.
4 cyl engines are inherently shit becasue they can't be balanced and have massive holes in the power strokage.
Inline 6 engines on the other hand can be perfectly balanced (it's the smallest balancable configuration) and have overlaping torque pulses so it's prectically impossible to stall them and they generalte prodigious torque from idle :)
LOOPYLEE1965
Post Sat Jul 16, 2005 12:37 am
jamesroools wrote:and finally the m21 2.4 d and td
dont talkabout diesels on the e30zone mate :bolt: :lol: :lol:
Andy325i
Post Sat Jul 16, 2005 12:49 am
24 valve is the way to go mate
Lordschleife
Post Sat Jul 16, 2005 12:59 am
rowemeister wrote: Also the S14 engine is pretty well fettled where the M20 has (if cash available) a lot of potential for good HP. Look @ some of the 2.7 conversions Bexley's have done.
Umm you can get a lot more out of an s14 if you want...
Cheers,
Robin
Lordschleife
Post Sat Jul 16, 2005 1:02 am
Turbo-Brown wrote:Depends what you mean by better.
4 cyl engines are inherently sh*t becasue they can't be balanced and have massive holes in the power strokage.
But a car with a 4pot will handle much better...
anyway my vote goes for the s14 and m10
Cheers,
Robin
Zayyan
Post Sat Jul 16, 2005 1:09 am
jamesroools wrote:and theres the m60, 2.0 and 2.5
All the 2.0 and 2.5 engines were either S14 (320is and M3 Evo Sport) or M20 (320i and 325i) weren't they?
johnono
Post Sat Jul 16, 2005 1:12 am
aw mate, any one as long as it dosnt clunk and rattle :lol:
i wouldnt mind a bullet proof 2.7 m20 with a maf though winkeye
Zayyan
Post Sat Jul 16, 2005 2:58 am
M60 is a V8 as I suspected.......don't think any E30s had these as standard unfortunately! :(
grandad318
Post Sat Jul 16, 2005 3:27 am
i have a 4 and 6 pot e30. i going for the practical vote as the m40 is so easy and a 'nice' engine to work on.
ian332isport
Post Sat Jul 16, 2005 7:57 am
Lordschleife wrote: But a car with a 4pot will handle much better...
This is actually a myth spread around by people lacking in cylinders :lol: In virtually all situations, there is no noticable difference between the handling of a 4 pot and a 6 pot.
A friend of mine has recently fitted an E36 M3 Evo lump in the front of an E30 M3, and finds the car drives just the same as it did with the S14 fitted. The car has also been driven by a number of quite accomplished drivers who also commented that it handles as well as any M3 (road and track).
Ian.
ian332isport
Post Sat Jul 16, 2005 7:59 am
The M20 was originally coded M60, but was later changed. BMW then used the M60 code for the later V8's.
Ian.
Lordschleife
Post Sat Jul 16, 2005 12:41 pm
Ian.
Sorry but I have to disagree, To say its a myth is clearly bollox, you cant ignore the physics of having all that extra weight in front of the front suspension struts
I've owned both 4 and 6 pot e30's and found the 6 pot ponderous on turn in where as the 4 pot is very sharp
BMW chose a 4 pot in the E30 m3 for a reason, as did Porsche in the 944/968 and those cars are considered some of the best handling ever made
I'm sure if you do a decent conversion you can eliminate some of this, depending on weight of engine used/positioning/suspension setup and of course if you used a flat 6 or v6 instead of a straight 6 then that would bring some weight backwards
But as I say you cant break the laws of physics
On the same lines have you notice the latest trend in car design where they're trying to bring the engines further back in the engine bay?
Cheers,
Robin
Karan
Post Sat Jul 16, 2005 12:56 pm
the only differnce i notice between 6 and 4 pots is in high speed 3rd gear drifting.... which lets face it u dont do everyday...
4 pots are more twitchy also.... 6 pots more stable at speed, but as i said... the neutral balance when in a 4 wheel slide isnt there in an m20 engined car like it would be in something like an m3..... thats all i can say from my limited experience, there is only that one issue!
Karan
japcarkiller
Post Sat Jul 16, 2005 2:02 pm
there is definatley a difference in how the 318 is and a 325 sport turns in on the bends.bigger engines will always feel a bit more slugish.
the test. pick a nice round about. drive at it in both doing about 50/60 keep the power steady and the 4 pot turns so readyly. i'm not saying the 6 pots are shazbat i love the 6 pot and will always go for 6 pot rightness over a 4 pot. but less wieght means it will turn better.
The Scumball.1000miles 1000minutes £1000 car
WWW.SCUMBALL.CO.UK
clicky clicky
Lordschleife
Post Sat Jul 16, 2005 2:34 pm
Karan wrote:the only differnce i notice between 6 and 4 pots is in high speed 3rd gear drifting.... which lets face it u dont do everyday...
Karan
Try throwing the car sharply into a tight roundabout, or doing a quick left/right switch and you should notice the difference.
I'm not saying the 6pots are bad - far from it, just the 4 pots are better from a handling point of view.
Obviously the 6pots have advantages in other areas
Oh and if people still do't believe me then:
325i
Skidpad, lateral g: 0.77
Slalom: 63.7 mph
318is
Skidpad, lateral g: 0.83
Slalom: 64.0 mph
M3
Skidpad, lateral g: 0.82
Slalom, 64.7 mph
Yes the differences are small, but still there and would soon add up through a series of difficult bends
Cheers,
Robin
Rearwheel_nick
Post Mon Jul 25, 2005 10:29 pm
4pot definately feels less fat up front and much prefer the turn in on a good old 4 pot. :mad: mind you 6 cylinders sounds good.
Dan318-is
Post Mon Jul 25, 2005 10:34 pm
at the end of the day all i can afford is four pot :(
getting back to the original question...
I have read the M10 responds very nicely to turbo charging and is supposed to be pretty bullet proof
Post Mon Jul 25, 2005 11:51 pm
its nothing to do with bein 6 pot or 4 pot re handling - its a weight thing you can get heavy 4 pots :wink:
Karan
Post Mon Jul 25, 2005 11:52 pm
but the s14 is actually a pretty heavy 4 pot......
Post Mon Jul 25, 2005 11:53 pm
all the E30 engines are good really apart from the M40 8O which isn't that bad
before u start i've had an M40
Post Mon Jul 25, 2005 11:58 pm
the m20 only weighs 11kgs more than the s14... i dont think it'll make that much difference to the handling...
Post Tue Jul 26, 2005 12:04 am
I've actually found now i can drive a bit better that with some good springs and shocks the 6 pot can handle very nicely not as agile but for what it lacks in 1mph corner speed it makes up for on the straights!
Andy325i
Post Tue Jul 26, 2005 12:05 am
E30BeemerLad wrote:getting back to the original question...
Am I right in thinking it was the M10 blocks that BMW used in the old F1 cars? Think thiey got about 1500 BHP out of them!!!!!
Also heard that they used to leave them outside to "weather" for a time :lol:
Post Tue Jul 26, 2005 12:12 am
S14 has an M10 block too, it was apparently developed off it!
Post Tue Jul 26, 2005 12:15 am
That's the basic blocks. Think they did one or two mods to them though, and they weren't quite so bulletproof at that sort of power!
Thought the blocks were always used ones, so that they've been relieved of stresses.
wayneE30
Post Tue Jul 26, 2005 12:23 am
so m10 sounds like the better engine what sort of bhp can be acheived from a standard m10?
