4 to 5 stud adapter?
Musashi
Fri Mar 27, 2009 11:50 pm
Is there such a thing as an adapter for a 4 to 5 stud? if yes does anyone know where i can find one and how much they are roughly? i have a set of 5 stud rims but the e30 i am looking at is 4 stud, any help would be appreciated thanks.
leeparkes
Fri Mar 27, 2009 11:52 pm
ive seen them on e-bay,what are the 5 stud wheels?
Sat Mar 28, 2009 12:03 am
gooner1
Out humping Reindeer
Sat Mar 28, 2009 9:21 am
Does anyone on here run their car with these on, and if so how/does it affect the drive?
miniblob
Sat Mar 28, 2009 9:37 am
I've used spacers on a mini with no issues, drove perfectly!!
Should be ok as long as the combination of spacer and wheels adds up to the correct offset (i think!)
Give it a try and let us know!!!
If you're not happy, you can always stick the spacers back on ebay!!
327 Touring with bass!!!
jaistanley
Sat Mar 28, 2009 1:22 pm
Fvck it. Why not get some blue LED washer jets too?
BMJG
Sat Mar 28, 2009 1:38 pm
Why not just take off the bits you need to convert to 5 stud from a E36 compact, it uses the same set up as a E30 just 5 stud :)
jaistanley
Sat Mar 28, 2009 3:35 pm
No it isn't.
oze30
Sat Mar 28, 2009 3:58 pm
from BMW 4 stud to other makes 5 stud, eg: 5x130 can be done. 4x100-5x120 is a bit sketchy. Jazzman did this, but used 2 sets of adapters, 4x100-5x100 then 5x100-5x120.
Colonel Sanders
Le Surrender Monkey.
Location: guernsey.... i mean france munching on garlic and drinking wine with my children.
Sat Mar 28, 2009 6:27 pm
you can get 4x100 to 5x120 but it puts the offset way out.
oze30
Wed Apr 01, 2009 10:42 am
gazm3
Fri Apr 03, 2009 12:38 am
Not a very good idea.
SUMPCRACKER
Fri Apr 03, 2009 1:05 am
So can you get 4x100 to 5x120? where from?
I have used adaptors on golfs before and it was fine.
oze30
Fri Apr 03, 2009 1:17 am
Concept-wheels website is down, so I dont think you can get them anymore!
Fri Apr 03, 2009 12:15 pm
Try ebay for adaptors
oze30
Fri Apr 03, 2009 8:42 pm
Nothing for 4x100 - 5x120
motorsport-tech.com (in the US do a set, but not sure if it's 2 adapters or the single one with the sandwich stud.)
oze30
Fri Apr 03, 2009 8:45 pm
gareth
Fri Apr 03, 2009 9:00 pm
4x100 to 5x120 PCD's clash so you can't simply have a plate to adapt the two, you need 2 adaptors which will throw the offset waaaay out (40mm ish) so you'll need some very odd offset wheels to accomodate them which kind of defeats the object.
what PCD are the wheels you're looking to fit?
Bavarian_Autotech
Sat Apr 04, 2009 6:56 pm
gazm3 wrote:Not a very good idea.
i agree.
ive seen these adaptors work loose on several occasions.
one guys wheel fell off on a polo !!!
