early high comp engine into later sport
maz1
Thu Mar 12, 2009 1:26 am
Will an early 2.5 engine fit into a later sport or is there additional work required.
thanks
327
Thu Mar 12, 2009 1:04 pm
Hi, fits ok, had this done to mine
zinderz
Thu Mar 12, 2009 4:56 pm
Be wary of slightly different wiring looms. May cause some issues with electric windows and the like. Well that was in my experience anyway.
Tech 1.. Old School Cool
zaust
Zone day release
Thu Mar 12, 2009 5:20 pm
You need to swap a couple bit's. (all easy) and best to have the engines side by side.
Bracket and sensor for the front pully as the gearbox one's will be redundent.
water way at the front with the cover's. and use the later injector rail on the early manifold.
You will be happy with the result fella.
M30 Tech 1 Touring on gas.
327ire
Thu Mar 12, 2009 5:31 pm
I had lots of trouble getting the conversion to spark, turned out to be that the older engine used a different system to locate TDC top dead center. The older one used a small hole on the surface of the disk, the new one uses 'missing tooth' which is a couple of the disks teeth missing on the edge of the disk.
Much easier to do with the engine out!!!
maz1
Thu Mar 12, 2009 6:44 pm
Thanks guys for all the info.
I will be getting it fitted by a mechanic but wanted to get all the bits I need before hand as I dont want any dramas. What actually makes the early engine higher compression...is it the head or is there a difference in the block or both.
Maz
maz1
Thu Mar 12, 2009 6:50 pm
Also my car has Air Con, That wouldnt make any difference would it? Will their be a noticable difference in performance.
Maz
ed325i
Thu Mar 12, 2009 6:52 pm
The pistons
zaust
Zone day release
Thu Mar 12, 2009 10:33 pm
You will notice it has better torque all through the rev range..
Enjoy.
