hella glass for my smoked lights
Karan
Post Sun Jul 10, 2005 3:45 pm
as above where do i get them, as both dipped beams are now cracked cos of my mway driving miles
i guess normal hella would be ok as they are clear neway
and how do i remove old glass and seal new glass on?
cheers
Karan
Simon
Post Sun Jul 10, 2005 4:04 pm
Follow Mrlee's guide in the articles section, I removed mine by using heat and a sharp blade running it around the sealant, be very careful though and always use adult supervision!!
Clear glass from any E30 lamp will do, best bet is to get a spare set of lamps from somewhere, doesn't matter either if it's bosch or hella.
Karan
Post Sun Jul 10, 2005 4:09 pm
yeh cheers ill get me mum to supervise!
id rather get hellas..... do gsf sell the glass for these?
Simon
Post Sun Jul 10, 2005 4:13 pm
Karan wrote:yeh cheers ill get me mum to supervise!
I think they sell the glass with the reflector, you could get one of these and remove the glass?
MISSY30
Post Sun Jul 10, 2005 9:29 pm
I've just bought the inserts from GSF, there Ԛ£26.50 + VAT.
There's this company in the U.S, But the lenses are plastic.
http://www.bmwlight.com/bmw_e30.htm
If you find anywhere that sell's just the lenses please let me know as I'm after replacement's for the Fog's, Cheers.
mrLEE30
Post Mon Jul 11, 2005 5:36 am
The Bosch and Hella units are a slightly different diameter and have the glass tabs in different locations, but with a bit of mild pursuasion thay can be made to fit, a little creative filing is required!!!
if you look below the top high beam lens is a bosch and the bottom is a hella lens (both on bosch frames) the hella is the bigger diameter lens so if your light units are hella, bosch lenses should be easy to fit!
