Alright guys
How easy is it to remove the headlining and replace?
Whats the best way of doing this?
Removing headlining
Removal is ok so long as you take your time. Never refitted one. Hardest bit is around the sunroof (if you have one) as some of the mechanism needs to be removed to get to some areas. You have to pop out the wind screen and rear screen and on two door cars, the rear side windows.
