m30 afm??????
325dude
Post Mon Jul 04, 2005 5:47 pm
allo all is it true about fitting an m30 afm to a 325 make alot of difference if so does anyone have one???????.............j
Ant
Retired Team Member
Retired Team Member
Post Mon Jul 04, 2005 5:52 pm
Fozzymonster had a fully modded unit for sale a while back dude, its been fitted with the 325i PCB and spring so tweaking should be easy as.
you'll need to increase your fuel pressure to around 3.5Bar to see the gains
for those that knock the swop.......... have you actually tried it ?? BMW SA used this AFM on the 2.7 powered evo models iirc
8bhp, 11 lbs ft are the best increase over stock I've seen reported, not bad for the outlay.
Demlotcrew
Post Mon Jul 04, 2005 6:30 pm
Bin it!
A
