325i and LSD's
wixer
Thu Jan 01, 2009 5:54 pm
Hi, new member here so my first post. Question is, do all 325i's have an limited slip diff ? If not, are they readily available and relatively straight forward to fit ?
Cloud
Mmmmmm Donuts!
Thu Jan 01, 2009 6:00 pm
No, quite, yes.
fuzzy
He who sleeps with "Gingers"
Thu Jan 01, 2009 6:03 pm
an option on all but 325 sports iirc. easily changed as a direct swap
**BANNED**
LSD was always an option. Once our new zone is running(some time next week I think) we will have a proper classified adds section to search for morsels like this.Expect to pay around £250. Held in by the driveshafts and 5 bolts.The top 4 are fiddly to reach and the diff is heavy so a decent jack is needed to lift/lower.Whilst the diff is on the floor it would be sensible to replace it's rear bush with either a Z3M item or a polybush one.
Youth is wasted on the young.
Thu Jan 01, 2009 6:59 pm
Only the 325i sports had them as standard.
There are 3 common ratio LSD's for 325i's and they are...
3.91 (the most common)
3.73 (the least common and most popular as its in the middle of the other two)
3.64
I have a 3.73 ratio LSD for sale for £300
andy1200
Thu Jan 01, 2009 7:02 pm
I ALSO HAVE ONE AND YOU CAN HAVE IT FOR £250
Thu Jan 01, 2009 7:09 pm
andy1200 wrote:I ALSO HAVE ONE AND YOU CAN HAVE IT FOR £250
3.73?!
wixer
Thu Jan 01, 2009 7:34 pm
Thanks may well be interested in buying one off you but I haven't yet got a car, probably getting one tomorrow and I'm unsure if it has one fitted yet.
wixer
Sun Jan 04, 2009 11:35 am
So got a car now, 325i Touring. What's the quickest way of seeing if it has an LSD fitted ? Any features on the diff casing that tells the two types of diff apart ?
toby
Sun Jan 04, 2009 11:42 am
Read zone wiki section. Link at the top of the page.
wixer
Sun Jan 04, 2009 11:51 am
Thanks mate, keep forgetting to check the Wiki's.
leeparkes
Sun Jan 04, 2009 12:06 pm
wixer wrote:So got a car now, 325i Touring. What's the quickest way of seeing if it has an LSD fitted ?
do a monumental wheelspin,if you leave 2 long stripes its a slipper!
e30bmlover
Ac Schnitzer prophet
Sun Jan 04, 2009 12:07 pm
3.73?!
its proberbly a 4.1 open diff barry lmao!
BadDave
Sun Jan 04, 2009 1:58 pm
Can be inconclusive
A mate tried it with his I.S and figured it had a slipper
2 mins later after i'd jacked up the rear.I proved it didn't.
Jack up 1 side of the car,and with the h/brake off and gearbox in neutral If you can spin the wheel that's in the air it's not a slipper
If you can't spin the wheel, then it's a slipper :D
Jon_Bmw
Dangerous when thinking
Sun Jan 04, 2009 2:27 pm
Some LSD's are so poor that they nearly become open! Check to see how well you can pull away with one wheel on the grass and one on tarmac.
Whilst on the subject of BMW LSD's, does the same 25% lock apply for on power and also coasting?
A standard LSD I presume allows 75% of slip when on the throttle and also 75% of slip when costing. Is that right?
Some diffs that are used in motorsport in RWD cars use different ramp rates to allow for differing lock up on throttle and coast, allowing for better drive(harsher lock up) on acceleration and less understeer into corners(less lock up, or more slip) on coast.
Quite common is 50/85 IIRC allowing for 50 lock up on Accel, and only 15% lock on coast to minimise understeer into a corner.
Could a Bmw LSD be developed to do this, or is it custom job time due to the design of BMW diffs? Kazz or TranX spring to mind.
Sun Jan 04, 2009 2:37 pm
Jon_Bmw wrote:Some LSD's are so poor that they nearly become open! Check to see how well you can pull away with one wheel on the grass and one on tarmac.
Welder FTW!! :)
BadDave
Sun Jan 04, 2009 2:41 pm
Jon_Bmw wrote: Could a Bmw LSD be developed to do this, or is it custom job time due to the design of BMW diffs? Kazz or TranX spring to mind.
Just need to modify the ramp IIRC
Kevo should be able to confirm
Jon_Bmw
Sun Jan 04, 2009 11:55 pm
Lol Jhonno! I have never looked in the e30 diff, and tbh I am not too sure how they work without looking at one. But can you change the accel ramp, and have a different coast ramp? Thats my question I guess, kevo?
Jon_Bmw
Wed Jan 07, 2009 6:18 pm
Bump.
