Clutch revoir cap.
orkboss
It seems a common issue on all E30's I have had. At some point the cap must have been screwed on too tight and split the cap.
Richy325iTouring
mines mint
Richy325iTouring
ok who asked what cap then ??
Wilson
Mines split
Adam318i
mines split to
Hopefully moisture getting in wont affect the fluid will it?
I love my Rice!
Demlotcrew
It will.Adam318i wrote:mines split to
I bought a new one i think it was like 3 pounds.
A
Turbo-Brown
- Boost Junkie
It will, but the cap doesn't seal it from the atmosphere anyway, just stops crap falling in, so don't worry too much about itAdam318i wrote:mines split to
EDIT> also stops the fluid spilling out (probably it's most important function thinking about it)
Martinaston
Yes and no (new one)
A1BMW325iSport
mine is fine, never had a problem
TOURINGDADDY
orkboss
I did notice replacement caps on Eurocarparts.com at Ԛ£2.35 +VAt but with the fiver dispatch charge it is not worth it unless you have a list of items to order.
johnl320
just got a good one from the breakers, did'nt cost a thing
The clutch resevoir cap has split on nearly every E30 I've had.
Forget the OE cap and keep your eyes open for suitable caps on other cars in the scrapyard. Tree of mine have caps from the clutch resevoir of early BL Metros, which fit perfectly.
brettski
had one fitted to mine the other day for Ԛ£2.50!
orkboss
Like they are common in scrapyards now!Brianmoooore wrote: Forget the OE cap and keep your eyes open for suitable caps on other cars in the scrapyard. Tree of mine have caps from the clutch resevoir of early BL Metros, which fit perfectly.
