have had an lsd on a 320 and its been just as much fun as a 325NayC wrote:LSD would be very handy, especally on a car with an engine like a 325i. If it was a 320 or lower, no point really unless you find a cheep second hand one, or it already has one. Also if you get some open space (where you know your not gonna knock a dent (or worse) into your kit and want to go sideways.... an LSD is always the way forward.
Again, rude car mate!
Clearly you are over estimating the use of this car..CG_Maintenance wrote:standard cab isnt much more heavyer than a touring
its not just about drifting
i think an lsd is essential for better traction
Erm no-one cares. They've posted for the same reason you have. The OP asked for peoples opinions.....omgyjya_switch7 wrote:Wow. A lot of sour people in here.It's his car, why do you all care.
I think if you are asking other people if you need an LSD then no, you do not need one.
Hardly, I'd say it was more a case of people not having a clue about the bigger picture with this car.. It is for cruising about in, try and use this in a manor which an LSD would benefit and the kit would last 2 secondsomgyjya_switch7 wrote:Wow. A lot of sour people in here.It's his car, why do you all care.
On 175 or 205 section budgets maybe..336tdse wrote:CG_Maintenance wrote:standard cab isnt much more heavyer than a touring
it is, a good 325i with no slipper will spin its arse of in the wet. and if it doesnt its not running properly.
Did not think he was asking if you need one. He asked if it was worth getting one. It is worth it. But no, he does not need it.[/quote]I think if you are asking other people if you need an LSD then no, you do not need one.
