e30 help mst/cyl & clunk at rear ?
savvi
Thu Dec 04, 2008 11:22 am
hi guys
86 e30 325i 320, 000 ks
well today i noticed when reversing applying the brakes to go ford
theres an obvious mild clunking noise in the rear can feel it a we bit to
would this be d/shaft guibo , or will the new drive shaft centre bearing im getting put in fix that coz when i looked at the new bearing holder the rubber seams to have front an rear play in it
also have recently replaced my master cylinder, when the i start to apply clutch pressure the master cylinder seems to click followed with some play 5mm id say before theres contact with clutch, other than that is fine its just irritating
all these we niggly problems b4 my first trackday 1/4 mile
always the way
any help appreciated
320ise
Thu Dec 04, 2008 1:15 pm
rear play could be the rear subframe/trailing arm bushes
