Le Mans Hero Damage! photos!
Toby_Unna
Boost Junkie
Post Tue Jun 28, 2005 9:29 pm
Hmm been getting a bit of driveline shudder since a few too many burnouts and a lot of trying to keep up with 911s at le mans. put a jack under it just now not expecting to see anything obvious...
think my front guibo coupling is on the way out, every hole has huge rips around it! look at all the rubber it's been spraying all over my tranny tunnel
guess i can't complain really :cool: also noticed the gear linkage's rear carrier has spat its rubber bush out somewhere, that'll be why my gearshift's been feeling so sh1te then :teehee:
TOURINGDADDY
Post Tue Jun 28, 2005 9:35 pm
:oops:
Geeman
Post Tue Jun 28, 2005 9:36 pm
:lol:
Well, at least it IS an obvious problem, and easily fixable... :wink:
Toby_Unna
Boost Junkie
Post Tue Jun 28, 2005 9:39 pm
i was worrying the centre bearing might have died, as you say this is an easy fix!
just glad it didn't let go completely at high speed, the prop can't actually come off because the gearbox output shaft nose sits an inch into the end of the prop, but loss of drive in the middle of france would have been a right b@stard!
Karan
Post Tue Jun 28, 2005 9:49 pm
Gad its something simple......
Hero damage rules!!!
well kind of....
Richy325iTouring
Post Tue Jun 28, 2005 9:54 pm
that looks worse than mine
billgatese30
Post Tue Jun 28, 2005 10:02 pm
and i thought richys was bad 8O
Karan
Post Tue Jun 28, 2005 10:05 pm
the one we changed on Daves was pretty funny
billgatese30
Post Tue Jun 28, 2005 10:07 pm
you mean that there was one left on daves??
SwirlyE30
Post Tue Jun 28, 2005 10:47 pm
That dont look good!
Excuse my ignorance, but where exactly is that on the car, i take it its attached to the prop, never got under my car to know much about it apart from the basics
1986 Chevrolet Corvette. 330ftlb torque....V8s rule!
Andy335Touring
Post Tue Jun 28, 2005 10:53 pm
I've not been doing loads of burn outs but i'd best check mine and the center coupling whilst i'm under there 8O
swirly,it sits in between the back of the gear box and the front of the prop
SwirlyE30
Post Tue Jun 28, 2005 10:56 pm
Oh right, cheers mate! No wonder its so fck! The amount of abuse on those must be pretty bad if your ragging the car around all the time.
Toby_Unna
Boost Junkie
Post Tue Jun 28, 2005 10:58 pm
Andy335Touring wrote:I've not been doing loads of burn outs
well why not, has it not got enough power or something :teehee:
i'm just glad i botheredm it was thunder and raining and i nearly stayed inside. don't think that was going to last much longer!
let me know if you need the cash for that manifold Andy. i can get it to you asap if you need it, haven't been up yet cos i've been a little busy but i still want it!
Andy335Touring
Post Tue Jun 28, 2005 11:07 pm
I could always do with the cash mate !
But no rush,it's got your name on it ;-)
oh and the silicone sealer on my exhaust flange is still holding up !
What sort of bore tubing was on that E36 exhaust silencer ?
I'm thinking of a home brew exhaust for my car if i can't get some thing decent for sensible money.
Toby_Unna
Boost Junkie
Post Wed Jun 29, 2005 12:02 am
no probs Andy will get the cash together asap.
the e36 silencer is the same bore as the m30 downpipes :cool: my whole system is welded together from 535i down pipes and that was identical to the front pipes of the e36 box.
not the ideal box, bit of a git to make it fit right. bought it because i knew it would flow a lot of gas (328is can make a lot of power on the standard exhaust) and cos it cost Ԛ£10!
makes a pretty quiet lightweight one box system :cool: mine is a bit raspy but it was a very cheap used box.
Rearwheel_nick
Post Wed Jun 29, 2005 1:26 am
same thing happened to mine at a drift day now it just bangs a lot makes the car really horrible to drive. too lazy to fix it yet haha.
