Rusted rear inner arch!
Greener
Tue Nov 11, 2008 12:42 pm
Has anyone had the pleasure of replacing a rear inner arch and if so is it possible without the removal of the rear quarter panel?
ROC
Tue Nov 11, 2008 5:04 pm
You can do it with the quarter panel still on. It is it easier to do if you are replacing the outer lip of the arch at the same time.
rossmc88
Tue Nov 11, 2008 5:17 pm
I replaced mine with fibre glass, but I don't think that would be recommended
Greener
Wed Nov 12, 2008 10:11 am
Thanks, I will give it a try!
clarko74
Wed Nov 12, 2008 10:18 am
Is it possible to get OEM replacement outer wheel arches? I've had a look on RealOEM and found the inner arches but can only find whole rear quarter panels for the outers.
And if the answer to the above is no, are the replacement outer arches from ECP or ebay that cost around £25 any good?
Apologies if this is a little off topic.
clarko74
ROC
Wed Nov 12, 2008 10:34 am
clarko,
BMW don't do the outer arch sections, they will only supply the entire rear quarter.
The repair panels from Beevers etc can be made to fit ok, just use as little of them as you can.
clarko74
Wed Nov 12, 2008 10:40 am
Cheers ROC, that saves me continuing to search RealOEM!
Greener
Wed Nov 12, 2008 10:44 am
Thanks Clarko, had a look on real OEM i need the inner outer of the arch if that makes sense, the arch is made from two sections. I have been phoning round to find one nobody seem to stocks them, Ive tried ECP, they dont, any other suggestions where i can get hold of one?
ROC
Wed Nov 12, 2008 10:55 am
Greener,
If you are talking about 6 or 7 on the diagram, they are only available from BMW.
Cheers,
Rich.
Greener
Wed Nov 12, 2008 6:50 pm
oh Bugger, thats what I thought!! Thanks for all your help.
Wed Nov 12, 2008 9:00 pm
Greener wrote:oh Bugger, thats what I thought!! Thanks for all your help.
You are making an assumption that all parts from ECP/GSF are cheaper than the same parts from BMW.
This is simply not true!
