fuel pump does not work; any suggestions?
fast2002
Mon Nov 10, 2008 3:27 am
my 89 325ic won't start. I checked for gas and the car is not getting any gas. I changed the relay both the main and the fuel pump relay and still no gas to the engine. I also changed out the #11 fuse as well. The only thing I remember doing was I removed the instrument cluster and install instrument rings.
Do I need to reset the computer? If so, HOW? The car was running find? Any suggestions?
maxfield
Mon Nov 10, 2008 9:53 am
The instrument cluster won't effect it anyway.
Try and work it with just a live and an earth. Then if it does you know there's a problem with the wiring.
Mon Nov 10, 2008 10:49 am
pop out the back seat and hit the cover over the pump hard,,,this got mine going again 8)
eko
Old timer
Mon Nov 10, 2008 10:59 am
Remove the fuel pump relay and bridge pins 87 and 30 together.
This should operate the pump,if it doesnt then you know the problem is associated with the pump itself.
Worth noting that ive come across quite a few where the 2 pin plug that goes to the pump gets a poor connection on the pins so worth checking that.
sati
Mon Nov 10, 2008 2:13 pm
12volts to pump , if it dont run replace the pump , if it works then bad conntions on the pump.
