Questions to ask before viewing/buying an E30 318iS?
Commited
Thu Oct 30, 2008 12:56 pm
Hi folks,
Looking for a few pointers. About 2 years ago, I bought my first BMW, an e30 318iS from BobS on this forum. It was a truly fantastic car and I loved using it, but my circumstances changed and I needed to do about 40000 miles a year, so I replaced it with a 530d Sport.
Anyway, that's gone, and I have a crappy Navara as a daily, and I'm looking for a weekend car once again. After trying loads of cars, including E36 318iS's & 325i's, I just keep on coming back to the e30 318iS.
The bit that I need help with is, what are the important things to ask before I make a trek to the UK with my hard earned?
The list I have so far:
Rust - where what how?
Timing chain tensioner - has it been done?
Leaks - oil&water from engine/rear boot lights/in car
Electrics - everything works?
Wheels/tyres good?
Any advisories on previous MOT?
Brakes and suspension - any attention needed here?
Am I missing anything?
Cheers :cool:
Mark
Mark
aj_mckay
Thu Oct 30, 2008 1:42 pm
All of the above, but with the chain find out when the whole thing was last replaced not just the tensioner - that's the easy bit!
As with all E30s rust would be extremely high on my list of stuff to check, esp. rear & inner arches, scuttle, bulk head, sills, roof, boot.
Would also be very worthwhile checking if the suspension is the original and if so what condition it's in. These will be 18 yrs old now and if original, the springs may well be fatigued and shocks may be leaky. Goes for bushes too.
There's plenty more and I'm sure others will chip in to make sure you cover it all :wink:
Good luck! You'll probably be able to get a bargain in the current market...
Cook318IS
Thu Oct 30, 2008 1:44 pm
and that the profile gasket has been done !!!!!
Cook318IS
Thu Oct 30, 2008 1:48 pm
this website comes in very handy for iS owners. its got a buyers guide, how to repair them and everything. much better than haines imo! http://www.esatclear.ie/~bpurcell/318is ... whenbuying
HTH :thumb:
Nay
Channel Island Crew
Channel Island Crew
Thu Oct 30, 2008 1:58 pm
Good info. Useful page!
Uni is killing the project.
Thu Oct 30, 2008 3:50 pm
Cook318IS wrote:and that the profile gasket has been done !!!!!
i feel a bit stupid asking this but what exactly is it, i keep hearing about it but have no idea where abouts it is :o: :o:
Cook318IS
Thu Oct 30, 2008 3:51 pm
its on the front of the engine iirc. Its easier to explain if you look on the etk for it, It all becomes clear then! :thumb:
Thu Oct 30, 2008 3:54 pm
http://www.realoem.com/bmw/showparts.do ... g=11&fg=10
so what happens when its gone, slight oil leak :?:
Cook318IS
Thu Oct 30, 2008 3:56 pm
thats the badger, item 10. IIRC, it gives you the same symptoms as a head gasket failure becuase that "hole" in the middle is where coolant flows
Thu Oct 30, 2008 3:59 pm
cool is it hard to change, might do mine if its easy and being only 3 quid it seems silly not too :D
aj_mckay
http://www.esatclear.ie/~bpurcell/318is ... filegasket
Cook318IS
Thu Oct 30, 2008 4:00 pm
iirc its a head off job and fairly big! i think its on that link ^ on the esatclear website
Thu Oct 30, 2008 4:01 pm
oh well, thanks for info ive been meaning to find out about it for ages :D
aj_mckay
Thu Oct 30, 2008 4:09 pm
Alex, chances are that if your car's done over 50k miles (which i suspect it has for a £500 iS) that this job has already been done somewhere along it's life...
It's a pretty safe bet anyway. I bought my iS without firm evidence of when/if it's been done (I think! Not really checked properly TBH) because it's a pretty safe assumption to make if the mileage is anything over the 50k mark.
Thu Oct 30, 2008 4:11 pm
:cool: 120,000 miles, so they get replaced with a better gasket
Thu Oct 30, 2008 4:26 pm
just reading thro its history and in 2000 it had loads of head work head set, head bolts, chain tensioner, thermostat, air pipes, pressure test, reface cyl head, reface 16 valves, reface 16 seats etc at a cost of £550 and it had only done 70k :eek: so chances it has been replaced then,
aj_mckay
yes, if it's been done it will have been replaced with a gasket made of something that doesn't get eaten away by the coolant... :mad:
Although it's only a 3 quid jobby of a gasket it's a pig of a job to have done as cook said cos you have to take the head off and all sorts.
Cook318IS
Thu Oct 30, 2008 4:27 pm
Alex wrote:just reading thro its history and in 2000 it had loads of head work head set, head bolts, chain tensioner, thermostat, air pipes, pressure test, reface cyl head, reface 16 valves, reface 16 seats etc at a cost of £550 and it had only done 70k :eek: so chances it has been replaced then,
£550 doesnt seem too bad imo! better that they did that and that it wasnt a nasty surprise for you! your car sounds more of a bargin by the day!
Thu Oct 30, 2008 4:31 pm
lol it is,
that was done 8 years ago mind you, but there is also recipts from 2002 saying investigate water leak, and recipts of changing radiator, all hoses and water pump and a few other bits and bobs (lets hope its not a plastic water pump:roll: ) plents of service history done every year :D
brakes were overhauled last year too :eek: new pads + shoes etc
Thu Oct 30, 2008 5:05 pm
the water pump cost 30 quid, fitted and supplied by a toyota garage :? :rolleyes:
do you recon they would have used a genuine part :?
Felix79
All loved up !
Thu Oct 30, 2008 6:00 pm
Ask them if it it Galvenisized? :banana:
Felix79 aka Dan
E85 Z4M Roadster
Gortour
Thu Oct 30, 2008 6:06 pm
Nice one Dan... :D
Another website to look at...
http://www.m42club.com/
DHFiS
Thu Oct 30, 2008 9:42 pm
Plenty of good advice above, also dont forget if it has a sun roof check it works. If you pour some water into the roof channel around the opening it should drain out under the car, if it doesnt then the drains are blocked.
Commited
Thu Oct 30, 2008 9:56 pm
Hey guys,
Thanks for all the great information above, I forgot how helpful this site is. Hopefully I'll be annoying you all with stupid questions more frequently from now on :cool:
Mark
Thu Oct 30, 2008 9:57 pm
Commited wrote:Hey guys,
dont worry we all need to ask silly questions winkeye
Thu Oct 30, 2008 9:59 pm
Don't forget to check the all-important glovebox torch works!
aj_mckay
Fri Oct 31, 2008 10:10 am
DHFiS wrote:Plenty of good advice above, also dont forget if it has a sun roof check it works. If you pour some water into the roof channel around the opening it should drain out under the car, if it doesnt then the drains are blocked.
Do you mean pour water on the roof when the sunroof is opened and let it drain into the suroof tray?
If the drains are blocked, how would you go about un-blocking them? jam a bit of wire down there or something??
Sorry - this is a new one for me!!! :o:
Fri Oct 31, 2008 1:41 pm
Yes, a couple of metres of bicycle outer brake cable works well, being stiff lengthwise yet flexible. You just shove it down the drain holes at the front of the sunroof tray on each side, Dyno-rod style.
DHFiS
Fri Oct 31, 2008 1:57 pm
I think there are 2 at the rear as well. If you pull back the trim in the boot you will see the plastic drain hose which exits he car via a vent hidden behind the bumper.
Check the corrosion in the sunroof panel as well, if its bad replace the whole thing.
aj_mckay
Fri Oct 31, 2008 2:01 pm
OK, so these drains come out in the front arches and through the boot and the rear bumper? OK, that's one for me to check this weekend then!! Not had any issues so far but will check to be sure anyway :thumb:
Commited
Sun Nov 02, 2008 1:43 pm
Off to look at a car in a couple of hours :banana:
Mark
Sun Nov 02, 2008 1:44 pm
good luck, hope its a good un :D
